Posted by John Rutzen on 01/04/2022 08:32:22:
Hi Jason, no it's a copper fuel pipe and the float is made of copper foil. The fuel in the stainless steel tank seems ok. I wonder if it is reacting with the aluminium float bowl, that seems to be where the gunge was concentrated. Robert, what is fuel stabiliser please?
I think you're very likely right about the float bowl. I would guess that the aluminium corrodes to form aluminium hydroxide gel which is what you found lurking in the carburettor.
re. using octane booster, unless this does something else apart from increasing the octane number, I'm not sure it would help, since the only significance of octane is its anti-knock properties (probably not important with the compression ratio you are using).
The simplest course of action is probably to drain the fuel from tank and carb if laying up the tractor for any period of time, e.g. over winter – I'm sure it wouldn't do any harm leaving it fueled for a few weeks.
Lovely model by the way – it sounds great!
