Rubber window glazing strip
Home Forums Related Hobbies including Vehicle Restoration Rubber window glazing strip
  • #579366
    Sam Longley 1
      @samlongley1
      Hopefully someone can help me here but I am having a bad hair daysad
      I am refurbishing the cab on our club Ford 4000 tractor & it involves removing some of the glass panels, dealing with rust, then replacing the glass.
      The glass is held in with a simple "H" section strip. I want to replicate that strip – I do NOT want the types with inserts etc – just the H type that one fixes with a cord.
      I have spent the last hour on tractor sites, auto factors & rubber seal sites but no one seems to do it. Plus I am having problems knowing what to google to find it. I keep coming up with door & window draught excluder strips
      Does anyone, into vehicle restoration, know where I can get a cheap H section strip, or what I should be googling for, please. I probably need about 10-15 metres, but not sure yet. Money is tight so I am very limited on spend
      Thanks Sam Longley
      Edited By Sam Longley 1 on 09/01/2022 09:19:51
      Sam Longley 1
        @samlongley1
        #579373
        martin haysom
          @martinhaysom48469
          woolies sell this sort of stuff google woolies car restoration cos if you just put in woolies you get information about a high street shop
          #579375
          Former Member
            @formermember12892
            #579376
            Sam Longley 1
              @samlongley1
              martin
              Thanks, But unfortunately they do not list the simple "H" section. Only the one with the break in the front.
              Edited By Sam Longley 1 on 09/01/2022 10:06:41
              #579385
              Andy Stopford
                @andystopford50521
                Try COH Baines of Tunbridge Wells
                #579388
                pgk pgk
                  @pgkpgk17461
                  Googling 'H section vehicle weatherstrip' might find what you need. Or try your local agri engineers for help.
                  pgk
                  #579393
                  Gerald Howarth
                    @geraldhowarth53631
                    Could try Seals Direct, https://www.sealsdirect.co.uk/, they seem to have most shapes in their catalogue.
                    #579397
                    Sam Longley 1
                      @samlongley1
                      Posted by Gerald Howarth on 09/01/2022 10:49:39:
                      Thanks but All the filler type
                      #579404
                      Sam Longley 1
                        @samlongley1
                        Posted by Andy Stopford on 09/01/2022 10:28:40:
                        Hurrah, Hurrah- Thankyou ,Thankyou laugh
                        Finally found it. Someone who does the actual section I was looking for & it is cheap( relatively that is!!) as well
                        Really apreciate that —Thanks for the linkyes
                        Sam Longley
                        Edited By Sam Longley 1 on 09/01/2022 11:43:03
                        #579413
                        Speedy Builder5
                          @speedybuilder5
                          Plus 1 for Seals Direct. Ring them up as they have some odd sections not listed. Used them on my Citroen 2CV windows.
                          Good tip, fit the seals on a warm day especially if you have tight radius on the corners.
                          #579414
                          Sam Longley 1
                            @samlongley1
                            Posted by Speedy Builder5 on 09/01/2022 12:45:44:
                            I have completely dismantled the cab & it is in my workshop for painting etc. so I will follow that advice & turn the heat up. I will not need a lot of persuasion in this weather.
                            Thanks.
