Rubber tyre glue
Rubber tyre glue
Home Forums Traction engines Rubber tyre glue
  • #682747
    Jonathon MC
      @jonathonmc86670
      I want glue solud rubber tyres to a water bowser. Its about45kg full weight and to be used on the road. Grateful for advice from someone who has done this succesfully. Thanks very much
      Jonathon
        Traction Engine builders tend to use marineflex these days as the previous two part primer & adhesive product is no longer made. Do make your tyre smaller dia than the wheel so it has to be stretched on as this reduces creep. Also don’t go for too soft a rubber
        #682878
        Jonathon MC
          @jonathonmc86670
          Thank you Jason. I was thinking of putting 1inch thick rubber on top of the rim without profiling it. Its not just laziness! I dont think cutting out that much rubber would work,might hide a couple of countersunk bolts in it.
          #685683
          Martin Johnson 1
            @martinjohnson1
            I use polyurethane adhesive like this:
            https://www.toolstation.com/puraflex-40-pu-sealant-adhesive/p85566?gclsrc%5B0%5D=3p.ds&gclsrc%5B1%5D=ds&mkwid=s_dm&pcrid=&pkw=&pmt=e&utm_source=bing&utm_medium=cpc&utm_campaign=_PMax_Adhesives+%26+Sealants&utm_term=4576029982151298&utm_content=Adhesives+%26+Sealants
            Other brands are available.
            For the rubber I used 16mm neoprene sheet which was sold for lining horse boxes.  A box of offcuts was very cheap.
            The above combination has worked fine over many seasons on the front wheels of a 4″ scale Burrell.
            Martin
            #685707
            Jonathon MC
              @jonathonmc86670
              Thank you Martin. Offcuts good idea😁
            Home Forums Traction engines Topics
