Router bit
Router bit
Home Forums Beginners questions Router bit
  • #644154
    Dalboy
      @dalboy
      I am thinking ahead as much as I can. Just put an order in for some cutters for the Farm boy as well as one for the rob roy later on. (they did not have the size I wanted)
      With the farm boy I need to round over some of the edges on the Ali parts of the build, would it be possible to use a wood router bit for this operation I have some HSS ones as well as TCT tipped ones.
      If this is possible it will save having to order from a different company yet again.
      It just seems as when ordering bits and pieces I have to order from many different companies instead of ordering from just one.
      I know Arceuro have a metric cutter which would do the job so if push comes to shove I will order that one but that will be yet another postage cost just for a small item. I do try to reduce postage and bulk things together.
      Edited By Dalboy on 06/05/2023 11:15:31
      Dalboy
        @dalboy
        #644159
        Chris Evans 6
          @chrisevans6
          I have successfully used a tct router cutter for corner rounding on Aluminium and Cast Iron. High spindle speed and don't get greedy with the depth of cut.
          #644160
          Baz
            @baz89810
            Only difference between a router bit and a proper corner rounding cutter is the shank diameter, as Chris says use a high spindle speed and take it gently. Both carbide and HSS ones work equally well.
            #644161
            Bo’sun
              @bosun58570
              Give it try. What's to lose? (apart from a router bit of course). I'm guessing the carbide insets in woodworking bits might be a bit thinner, and maybe not as well supported. I'd try it with 1//2" shank bits if you can, for increased rigidity if nothing else.
              As Chris suggests, take it easy. Good luck and let us know how you get on.
              #644162
              Dalboy
                @dalboy
                Thank you Guys. At the moment this is the only job I need it for
                #644173
                  I've done it several times. The only thing you have to watch is that if you are working into an internal corner then the generally larger diameter of a router bit won't get into the corner as far.
                  Diameter of cutter also determines speed so a router bit would generally need to run slower than the smaller dia of your typical milling cutter but a sit is aluminium you should be able to give it some beans.
                  #644178
                  Dalboy
                    @dalboy
                    Posted by JasonB on 06/05/2023 13:15:35:
                    Part of what needs cutting I will need to stop short anyway and finish those by hand and blend them in
