Rounded off hex head screws.
Home Forums Help and Assistance! (Offered or Wanted) Rounded off hex head screws.
  • #246522
    Speedy Builder5
      @speedybuilder5
      How about trying one of those drill extractors used for cross head screws. Use lots of pressure and not many revs. I bought some cheap ones, but the screw won !!
      BobH
      MW
        @mw27036
        Hi speedy,
        Lots of good hints on here but i've lost faith in those "easy outs" bit of a misnomer!
        Michael W
        #247807
        Howard Lewis
          @howardlewis46836
          Can only agree with the man who said that the Easyout was most misnamed tool in the shop.
          SOMETIMES, if you can access the nut or parent metal into which the screw id tapped, a succesion of blows around the outside when placed on a suitable "anvil" will break any rust/corrosion.
          Obviously can't be used on a casting of any size.
          +1 for the left hand drill, probably a mixture of torque with a little local heating.
          On larger sizes, if a hardened screw, the tipped drills used at high speed with lots of pressure will work. But you no longer see them at Shows, (i have some that need replacing. Trying to use a small masonry drill, instead, did not work, and it wrecked the masonry drill!)
          #247814
          Hopper
            @hopper
            Left-handed drill bits are the handiest thing I know for stuck bolts. Usually the bolt will spin loose before the drilling is finished.
            With loose allen keys, you can put a little grinding paste on the allen key and in the hex hole to get a better grip. Surprising result quite often.
