Rothenberger Super Fire 2 Torch
Home Forums Workshop Tools and Tooling Rothenberger Super Fire 2 Torch
Viewing 3 posts - 26 through 28 (of 28 total)
  • #543727
    Bo’sun
      @bosun58570
      Thank you Bill,
      I've seen two instances of them bursting into flames, likely the same as you've seen. Luckily, my torch wasn't alight when I noticed the leak, and quite a big leak at that.
      I'm currently looking at Bullfinch and Vortex.
      noel shelley
        @noelshelley55608
        A bullfinch handle and a propane regulator, You can go from pinpoint , for jewellery to a raging inferno that would make HELL look cool, JUSTby changing the burner ! Bomb proof to ! Noel
        #543763
        Bill Phinn
          @billphinn90025
          It's perhaps worth noting that in their Standard Torch System instruction leaflet Bullfinch stipulate surprisingly large minimum cylinder requirements for the medium-sized burners upwards.
          I'm not sure how necessary it is to slavishly follow their advice on this count; I have used large KW-rated Sievert burners at 4 Bar off a 13kg propane tank, when, according to Bullfinch, burners of theirs this large should only be run from a 47KG cylinder.
          Of course if Bo'sun is only after the kind of Bullfinch torch that screws directly on to disposable Bernzomatic-style cylinders, Bullfinch's caveat won't apply.
