rotary to screw force calculation
  • #15261
    malcolm mill
      @malcolmmill78623
      calculate lifting
      malcolm mill
        @malcolmmill78623
        I suppose the title says it all……
        a stepper motor turns in a circular motion with a torque of 1N and shaft diameter 5mm
        the motor shaft is then direct coupled to a 8mm x 2mm pitch lead screw
        if set vertically with shaft and screw in the same plane what is the lifting force of the screw
        #455530
          malcolm mill
            @malcolmmill78623
            wonderful link
            BUT it means absolutely nothing to me….
            I'm 70, I'm on a lot of painkiller and too easily confused and frustrated.
            to make it worse… I was an electronics designer to chip gate level and was fluent in 5 computer languages plus binary / boolean…. and find my current lack of accruity very frustrating
            thanks anyway michael
            #455536
            Gary Wooding
              @garywooding25363
              The torque of the motor = 1N, or 1 Newton at 1 meter (1000mm). The effort, E, provided by the motor is then 2*PI*1000 Newtons for each revolution. For each revolution of the screw the load , L, is lifted through 5mm.
              Assuming no loss due to friction, then the effort E must equal load L, so…
              2*PI*1000 = L*5, therefore L = 2*PI*1000/5 = 400*PI Newtons, or approx 128 Kg.
              If the leadscrew is a ball-screw then friction will be very low and the load should be a little over 100Kg, otherwise friction is likely to be nearer 80% and the load will be reduced to around 35Kg at a guess.
              #455557
                The sort of question makes my brain fizz! Trying to follow Gary's answer, he says "The effort, E, provided by the motor is then 2*PI*1000 Newtons for each revolution." Is that right? I imagine 2N at 500mm, 4N at 250mm etc.
                Michael's calculator, making everything zero apart from the pitch and diameter, suggests about 250N for a 1N input. That's about 25kg lift assuming zero friction. With friction assumed to be 80%, about 2kg.
                I've no idea if that's right – need more coffee…
                Mick B1
                  @mickb1
                  Posted by Gary Wooding on 05/03/2020 14:13:54:
                  How's that when the stepper's directly coupled to the 2mm pitch leadscrew?
                  Oh Gordon Bennett, what've I uneashed by asking that… ?? surpriselaugh
                  #455564
                  John Haine
                    @johnhaine32865
                    It might make it clearer to think in energy terms. So if the motor is exerting 1 newton-metre torque, that's a force of 1 newton (roughly an apple!) at the end of a 1 metre lever. In one revoultion the force moves 2 pi metres, so energy is about 6 joules. If that goes into lifting a weight by 2mm = 0.002 metres, the lifting force must be such as to absorb the same amount of energy. So:
                    F x 0.002 = 6, or F is ~3000 Newtons. One Kg weight is 9.81, or about 10, Newtons, so maximum lift force is about 300 kg. This assumes no friction in the ball screw.
                    #455569
                    Gary Wooding
                      @garywooding25363
                      Whoops, I used a pitch of 5mm where it should have been 2mm. So multiply my 128Kg by 5/2 to give 320Kg.
                      #455574
                      malcolm mill
                        @malcolmmill78623
                        THANKS to everybody….. I can now make educated reasoning on motor spec and finish my project……..
                        theres nothing more annoying than producing an elegant construction, simply for the motor to start clicking and going nowhere.
                        I've enjoyed the too and fro between you all……. the sort of thing I used to love taking part in but, alas, no longer can
                        malcolm
                        #455577
                          Posted by malcolm mill on 05/03/2020 14:06:29:
                          wonderful link
                          Sorry about that, Malcolm
                          I was on the ‘bus to Manchester, and I grabbed what I thought looked promising
                          … But it is a bit heavy, isn’t it !!
                          Just had another thought though … which I will throw into the pot:
                          • The diameter of the motor shaft is irrelevant, because it’s directly coupled to the screw
                          • To a first approximation: The distance travelled in one rotation is the circumference of the screw
                          • The linear displacement in one rotation is the pitch of the screw
                          • That gives us a ‘gear ratio’
                          I must leave it to others to do the juggling … I’m on another bumpy ‘bus ride.
                          Edit: belatedly reading the last few posts suggests that you’re there already.
                          Edit: For handy reference: This calculator looks more relevant …
                          https://www.daycounter.com/Calculators/Lead-Screw-Force-Torque-Calculator.phtml
                          Edited By Michael Gilligan on 05/03/2020 19:24:49
                          #455589
                          duncan webster 1
                            @duncanwebster1
                            work done by motor is torque (N.m) * angular rotation in radians. There are 2*pi radians in one revolution, so work done in one rev is 2*pi*torque
                            work done by leadscrew in one revolution is force * distance (metres)
                            In the absence of friction (ballscrew and rolling element thrust bearing) the force is 2*pi*torque/distance.
                            However OP has quoted torque in N which isn't right, should be Newton.metres, Newton.cm, or N.mm.
                            If plain screw and thrust bearing, you'll lose a lot due to friction. The sums get a lot more complicated depending on helix angle of leadscrew, coeff of friction, diameter of thrust bearing, diameter of leadscrew and included angle of thread.
                            #455744
                            Howard Lewis
                              @howardlewis46836
                              If direct coupled to the Leadscrew, the motor shaft diameter does not come into the calculation,
                              Effectively, if you unravel a screw thread, it becomes a simple lever.
                              If you think of the Mechanical Advantage as being Load / Effort , the Effort moves (2 Pi x 8 ) mm to lift the Load 2 mm This is 50.26 mm movement by the Effort to produce 2 mm movement of the Load, so the Mechanical Advantage is 25.13
                              Neglecting friction, this means that applying a 1N force can exert a force of 25.13N.
                              Friction will reduce this figure quite markedly..
                              This overly simplistic, since rather than 8mm it would be more accurate to base calculations on the pitch line diameter.of the thread.
                              But a screwthread can exert a lot of force, that's why you don't apply much force on the handle, but turn it a lot of times, to jack up your car!
