On
23 August 2024 at 15:20 moonman Said:
I’m wondering what tables you guys use and if you recommend them or not? I don’t want to go mad budget wise but at the same time I want something worth keeping.
First make sure you understand the between a plain table that just rotates, an indexer which can be locked at a limited number of angles, and a rotary table driven by a worm and handle that can be positioned accurately at arbitrary angles. The latter is often accessorised with a clock-hand / holed disc memory aid, attached where the handle goes. Not needed for easy work like putting a hex head on a nut, but valuable when cutting lots of teeth on a big gearwheel.
![LrgRotaryTableUse03](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
A stepper motor and index software is a popular alternative to the clock because clocks are subject to human error, and the software does all the hard work.
Most of us go for a full rotary table.
The choices are:
- Cough up for a new industrial rotary table. Many newcomers are keen on buying the best until they discover industrial grade tools are typically 5 to 20 times more expensive than the hobby version! A nice Bison costs about £6000. Up to you to decide if that’s “mad budget wise” or not! The item is guaranteed.
- Search for a second-hand industrial table. The risk here is buying SECONDHAND. The item’s history and condition matter far more than who made it. Anything between scrap and as new. Unlikely to be guaranteed so best to inspect in person and know what to look for.
- Buy a new hobby table. Many different makers, typically copying a long out of patent protection western design, some good others too cheap. If a lemon turns up, the game is replacing it or money back. That’s when the vendor matters!
The internet gives purchasers plenty of opportunity to take risks! Some examples:
- Buy from abroad, saving loads of money unless it goes wrong! Unexpected customs charges on more expensive goods. UK consumer protection does not apply, so dealing with a lemon is your problem.
- Buy via a UK Box Shifter like Vevor. These firms aren’t tool suppliers so don’t expect any technical support. They sell whatever they pick up, so quality varies. UK consumer protection applies, so lemons are relatively low-risk
- Buy from a UK hobby supplier. UK consumer protection applies. They are a little more expensive, but hobby suppliers are more likely to care about consistency than a box-shifter, and to understand the product, and to care about their reputation. I normally buy from ArcEuro and Warco, but have also bought from RDG and others without complaint.
I suggest who the table is bought from matters more than the brand. Being a pessimist, but not a fuss-pot perfectionist seeking to buy heirlooms, I go for option 3.
Important I think to keep a sense of perspective when buying hobby tools. Some consider £500 to be a lot of money, and it isn’t! Don’t expect a £500 rotary table to be as well finished or as accurate as the industrial version, but my experience is that mid-range tools are ‘fit for purpose’ in a hobby workshop. Unless something special is required, don’t fret! For what it’s worth, mine came from Warco: About 10 years old, and still going strong, though I take care not to thrash it.
