rotary table
rotary table
Home Forums Workshop Tools and Tooling rotary table
  • #596118
    lee hawkins 1
      @leehawkins1
      Hello all,
      I have the chance to buy a 10'' rotary table, it has a name plate on the side says Hofmann, it's in very little used condition, it still has all it's paint apart from a couple of scuff marks, excellent condition, it works so smoothly, with no backlash that I can detect , table is unmarked,
      I have never used or own a rotary table, I only do hobby stuff but been told that I can buy it for £150 and your getting a bargain at that price
      lee hawkins 1
        @leehawkins1
        rotary table
        #596119
        Hopper
          @hopper
          Hoffman is high end gear so probably a good buy if its in good condition and has the index plates etc with it. But 10"? Will you need a hoist to lift it on and off the milling machine? They weigh about 80 lbs or more And is your milling machine big enough to take it?
          #596124
          Chris Evans 6
            @chrisevans6
            I had a 10" Hoffman rotary table for many year's, an excellent piece of kit. I sold it and bought a Vertex 10" rotary table because I thought the horizontal and vertical clamping feature of the Vertex would be useful. Reality is I have only used the vertical clamping a couple of times and I regret letting the Hoffman go. A 10" rotary is ideal for my Bridgeport and is about as much as I can lift, I have a 14" rotary used every now and again but that required making a wheeled bench to get on the machine.
            Go grab the Hoffman at £150 a real steal.
            #596126
            Nigel McBurney 1
              @nigelmcburney1
              At that bargain price I would quickly do the deal,I have a Hoffman universal dividing head and it is a top class piece of equipment. regarding size with rotary tables within reason the bigger the better in order to get more clamping space, I did have a French made really substantial 12 inch rotary table,ex Dufor mill ,very heavy,so with old age I did decide to swap it for a 10 inch Taylor Hobson table,again a top class uk manufacturer in its day, and it is still maneageable and suits the smaller 00 Omnimill i now have.
              #596137
                Um, a rotary table simplifies many operations – whenever a job needs to be turned through an angle: making gears, drilling PCD, cutting wheel spokes, adding flats to rods, cutting arcs, and much else. But it's a waste of space and money unless you need one!
                Otherwise sounds like a good buy apart from the size and weight. A 10" table is too big and heavy for smaller milling machines – Bridgeport size and up needed. How much does the table weigh? An elderly weakling like myself might struggle to lift it!
                larry phelan 1
                  @larryphelan1
                  To all you 70 yr old weaklings out there :
                  Build a lifting platform as I did, problem solved ! Best thing I ever made !
                  Details in my album and made from cheapy cheapy stuff.
                  Big milling vises/ rotary tables/ big chucks / loading car/van ? all the same to it.
                  Does wonders for the back too !cheeky
                  #596211
                  Dave Halford
                    @davehalford22513
                    Sometimes you need the centre of the table under the centre of the cutter on a Vertical mill and that needs a big machine.
                    It's a steal because no one wants them in industry due to CNC and not many ME's want them either. Great for drilling holes in a circle on a drilling table with a car jack underneath for extra support.
                    #596240
                    old mart
                      @oldmart
                      You need to state the mill you will be fitting it to.
                      #596247
                      David-Clark 1
                        @david-clark1
                        I heard about someone who had Hoffman. I think it was a rotary table and it needed regressing. Problem was the grease was into three figures.
                        Just check if it works ok and what grease he uses.
                        #596378
                        Howard Lewis
                          @howardlewis46836
                          A Rotary Table, is a very useful item, especially if Division Plates come with it.
                          The ability to mount wit with the face vertical, under a vertical mill, will allow gear cutting.
                          A table of the Divisions available will be needed. Otherwise, it will take a time to make up a spreadsheet for nthis.
                          (It may be possible to change some of the formulae in my spreadsheet for the 90:1 ratio Vertex HV6, to take account of the probably different gear ratio of the Hoffman.
                          But a 10" table is a big one, so may be too large to fit into the table of a smaller mill., in either orientation.
                          #596439
                          lee hawkins 1
                            @leehawkins1
                            Thanks everyone. I appreciate the advice
                            I thought about all the times , if only I had a rotary table, and there was quite a few times in the past, so I went ahead and bought the Hofmann, it's in such good condition and operated so smoothly., I had to buy it for the price,
                            You hear some say , I have a rotary table and I hardly use it , But the point is they do own one
                            #596444
                              Good move, Lee yes
                              Ebenezer Good
                                @ebenezergood76202
                                I'm the proud owner of an almost mint 10" Hoffman too, lovely thing but #### heavy!
