rotary encoder dro
rotary encoder dro
Home Forums Model Engineer & Workshop rotary encoder dro
  • #38598
    peter ravenscroft
      @peterravenscroft57700
      tailstock dro by duncan webster
      peter ravenscroft
        hello
        is it posible to have a copy of the drawings and the code for the tailstock dro in issue 301
        regards
        peter
        #525984
        duncan webster 1
          @duncanwebster1
          send me a pm and I'll forward the code and drawing. The drawing is pretty basic, only enough for me to make it, but it will give you the idea. Will need fine tuning to suit whatever lathe you have
          #526022
          Derrick Ardron
            @derrickardron43935
            Very interesting article and looks like not too difficult as a first proper Arduino project. Could I also request a copy of the drawing and the code., Many thanks Derrick
            #526058
            Matt Harrington
              @mattharrington87221
              Duncan, I'd be interested as well. Do you think it is possible to hook up to a Sino DRO?
              Regards, Matt
              #526076
              Greensands
                @greensands
                Hi – Could you also send a copy to me. Looks to be an ideal starter project. Thank you
                #526111
                duncan webster 1
                  @duncanwebster1
                  I've sent details to Roy Oxley and Michael Gilligan. Others who have requested via pm or above need to send me their email address by pm (click on 'message member' ) . I've tried to send it to Emgee, but it wouldn't accept the email address.
                  Would it connect to a Sino? Most scales increment on 0.005mm resolution, so you'd need to arrange 200 edges per mm travel of tailstock. My set up gives 1600 edges for 0.3", which is 209.973 edges per mm. However you could change the belt drive ratio gear it up, or the software could be arranged to do a conversion, but it would be a bit involved. Belt ratio would depend on leadscrew pitch, if you had a metric pitch it might work out easier
                  edit to get rid of smiley,
                  Edited By duncan webster on 10/02/2021 12:21:06
                  #526124
                    Thanks in anticipation, Duncan
                    [ it’s not yet arrived ]
                    … Much appreciated yes
                    Ady1
                      @ady1
                      If you're going to fire files about then try and keep them under 20MB
                      #526192
                      duncan webster 1
                        @duncanwebster1
                        well under 500kb
                        I think I've replied to all who have contacted me so far, if not please pm me again. Don't forget to attach your email address, I can't attach files to a reply on the forum
                        #526201
                          Posted by duncan webster on 10/02/2021 16:49:18:
                          well under 500kb
                          Thanks, Duncan
                          … regrettably, I have still not received a message.
                            For the benefit of anyone else who uses an iOS device for their eMail :
                            Duncan’s nicely annotated code < TailDRO_4.ino > opens tidily in an App called DraftPad
                            https://apps.apple.com/gb/app/draftpad/id358067114
                            Edited By Michael Gilligan on 11/02/2021 10:06:04
                            #526481
                            peter ravenscroft
                              hi duncan
                              many thanks for taking the time and the trouble to send me the filesregards
                              peter
                              #535021
                              peter ravenscroft
                                hi duncan
                                many thanks for the files i have built one and it works a treat clever programing
                                regards
                                peter
