Edith Hall (cited by Frances, above) also considered the knitting-mould idea, and rejected another suggestion of it being a surveying instrument; but also explained one had been found on a sceptre in a very wealthy woman’s grave.
I thought that suggests it might simply have been ornamental!
I have made a hollow dodecahedron, from brass sheet, as a Christmas present for a girlfriend. It was a dodecahedron of two halves (sorry, couldn’t resist that…) held together by a central, internal column topped by an ornamental nut. Each upper half’s pentagonal side faces were drilled with a pentagonal pattern of small holes, and the object was meant as a pomander but Nina used it to stand ornamental dried grasses.
That was some 40-odd years ago…. If is still survives I wonder if in the distant future some archaeologist and comet’s-tail of on-line experts would be wondering what Act of Divination to which Deities had needed my dodecahedron. They’d probably be wrong. Nina was a Wiccan and they don’t use dodecahedra!
” We had lots of fun with the Antikythera puzzle, but no real success.”
Errr, Michael, the Antikythera (named after the island, not its unknown original name) is now generally regarded by them as are paid to know these things, having taken a nine-tonne medical scanner all the way to Greece to analyse it, as an astronomical calculator.
The device that gave us so much fun with no success at all, a few years ago now, was labelled “Copyright 1908” if I recall correctly, and the 16-times table; but bore no maker’s name, and we found no clear pattern to its curious numerical scales on concentric discs. (It may have had a name on some component or case that had long been lost.)
I followed some pretty arcane lines of hunch-led enquiry with no luck.
Remember?
