One item that I wanted to try and replicate on this engine was the metal cylinder cladding often seen on American engines that has a series of recessed "slots" in the surface. I started out by turning down some aluminium tube to the right diameters and then milling clearance for the valve block and exhaust boss.
I then made up a couple of plugs so it could be held in a 3-jaw chuck on the rotary table with tailstock support to mill the 2mm wide grooves.
As I have a 6mm Weldon shank holder for the SX2.7 I opted to use that as it made it easier to see the end of the small cutter, a bit of masking tape with some marks added made sure I stopped feeding at the right place as I don't have a DRO on this machine.
With the milling complete the tube was cut down the middle with my thinnest slitting saw so it could be fitted, a small loose piece also had to be made as it was not possible to slide the exhaust side straight into place.
The few images of engines that I managed to find showed glass oilers for the main bearings and trunk guide, the tops and bottoms were straightforward turning and the "glass" was turned and polished from a square strip cut off a sheet of 6mm perspex.
The governors fitted to these engines look to be Gardner ones which I managed to find a few larger images of, they varied a bit so I took features from each for my design, this is a typical one and you can also just make out the cylinder cladding which is what I was after.
A piece of gauge plate was machined to the required 12mm width and a concave cutting edge milled with a 16mm cutter followed by a slight rounding of the two "points" This was then used to form the body of the governor.
After which the flat sides and various holes were added
The 12 & 18 tooth bevel gears were approx 0.4MOD and cut with a single point cutter
The rest was very small turning and milling work to get to this stage
The 3/16" stainless balls were heated to soften them before being drilled 1.0mm, I decided to fix them with Loctite rather than threading
Due to the small size I decided early on that it would not be a functioning item but just wanted the balls to spin round and swing out.
