Robey 6-7hp Works traction engine drawings for sale.
Home Forums Traction engines Robey 6-7hp Works traction engine drawings for sale.
  • #634992
    Tom Antell
      @tomantell22118
      have been sorting through what drawings I have and realised I have a near complete set except for one or two general arrangement drawings, clack valve and mud doors, but I can help with those details. This is a great opportunity for someone to have a go at making a model or even full size if they were daring enough (a good amount of patterns are already dotted around the country). Aside from that every other component part, nut and bolt to make one is included. Unlike what I have shared before these are professionally scanned drawings and not photographed copies. They cover 6 or 7hp single cylinder and compound traction engines/Road Locomotives 2 or 3 speeds. Half 3/4 or full length canopy drawings are also included. I do not have a 4 foot 6 solid flywheel drawing. But I do have a rough copy of a 4 foot solid flywheel that I have scaled up, as well as them appearing on some arrangement drawings. The set comprises of 97 drawings all in A1 size. The drawings included are listed below.
      Tom Antell
        @tomantell22118
        #634994
        Tom Antell
          @tomantell22118
          Winding-Forward-Drum-for-6-7hp-Traction-Engines.
          Weigh-Shaft-Brackets-6-7hp-Compound-Traction-Engines.
          Trunk-Guides-Weigh-Shaft-Bracket-Slide-and-Safety-Valve-for-6-7-hp-Traction-Engines.
          Trunk-Guides-Slide-and-Safety-Valves-for-Compound-6-7hp-Traction-Engines.
          Three-Speed-Gearing-for-6-7-hp-Traction-Engines.
          Third-Motion-Shaft-and-Hind-Axle-Bearings-for-6-7hp-Traction-Engines-Without-Springs.
          Stop-Valve-Details-for-6-7-8-10hp-Traction-Engines.
          Steerage-Reversing-Lever-for-6-7hp-Traction-Engines.
          Steerage-Reversing-Lever-6-7hp-Traction-Engines.
          Steam-Elbow-for-Boiler-Front-6-7hp-Traction-Engines.
          Standard-Water-Lifter-Hose-Pipe-Carriers-for-6-7-8-10hp-Traction-Engines.
          Standard-Tender-for-67hp-Traction-Engines.
          Standard-Sheet-Check-Valves-1.
          Standard-Sheet-Blow-off-Cocks.
          Standard-Boiler-Mountings-for-Tractors-and-Traction-Engines.
          Standard-Boiler-for-6hp-Single-Compound-Traction-Engine.
          Standard-Boiler-for-7hp-Single-Compound-Traction-Engine.
          Spring-Gear-for-67hp-Traction-Engines.
          Special-Road-Wheels-for-6hp-Traction-Engine-5ft-6-Dia.
          Special-Hind-Road-Wheels-for-6-7hp-Traction-Engines-6ft6-Dia.
          Special-Disc-Crankshaft-for-7hp-3-speed-Compound-Traction-Engine.
          Special-Deep-Sided-Front-Tank-for-7hp-Traction-Engine.
          Spark-Arrestor-Smokebox-door-for-6-7hp-Traction-Engines.
          Shafts-Axles-for-67hp-Single-Compound-Traction-Engines.
          Seating-for-Cylinder-Bored-Guide-Support-6-7hp-Traction-Engines.
          Rope-Guide-Rollers-Rear-Tank-Fittings-for-6-7-8-10hp-Traction-Engines.
          Road-Wheels-for-6-7hp-Traction-Engines-Road-Locomotive.
          Rim-Brake-Gear-for-6-7hp-Traction-Engines.
          Reversing-Gear-for-5-6-7hp-Traction-Engines.
          Rack-for-Tender-67-8-10hp-Traction-Engines.
          Position-of-Bearing-for-Tractors-Traction-Engines.
          Pickering-Governor-Arrangement-6-7hp-Single-Tractions.
          Pickering-Governor-Whistle-for-6-7hp-Traction-Engines.
          Outline-Arrangement-6hp-Single-Cylinder-Traction-Engine.
          Nameplates-on-Smokebox-Door-for-all-Traction-Engines.
          Machined-Crank-6hp-Single-Cylinder-Traction-Engine.
          Left-Hand-Reversing-Gear-Details-6-7hp-Traction-Engines.
          Large-Boiler-for-6hp-Single-Compound-Traction-Engines.
          Injector-Waterlifter-Arrangement-for-6-7hp-Traction-Engines.
          Hind-Road-Wheels-for-6-7hp-Colonial-Traction-Engine-6ft-Dia.
          Half-Canopy-for-67hp-Traction-Engines.
          Guide-Bars-Slide-Safety-Valves-for-67hp-Single-Tractions.
          General-Arrangement-7hp-Single-Cylinder-Traction-light-type.
          Gearing-for-6-7hp-Traction-Engines.
          Geared-Down-Pump-Details-67hp-Traction-Engine.
          Gear-Guard-for-6-7hp-Traction-Engines.
          Gear-Case-for-6-7hp-Hp-Traction-Engine-3-speed.
          Gauge-Guard-for-58-and-12-Inch-Guages-Glasses.
          Full-Length-Canopy-6-7hp-Traction-Engines.
          Front-Tank-for-6-7hp-Tractions-Road-Locos.
          Front-Tank-6-7hp-Tractions-and-Road-Locos.
          Front-Tank-Steerage-for-6-7hp-Traction-Engines.
          Fore-Carriage-Front-Wheels-Locking-Plate-for-6-7hp-Traction-Engines.
          Flywheel-Brake-For-6-7hp-Traction-Engines.
          Flared-later-design-Tender-6-7hp-Traction-Engines.
          Fire-Hole-Doors-for-Tractors-Traction-Engines.
          Feed-Pump-for-6-7hp-Traction-Engines.
          Exhaust-Pipe-Flywheel-Chimney-Drain-Cocks-Footboard-Lagging-6-7hp-Traction-Engines.
          Exhaust-Pipe-and-Governor-for-6-7hp-Compound-Traction-Engines.
          Engine-Motion-Covers-for-6-7hp-Traction-Engines.
          Disc-Flywheel-4-foot-Dia.
          Details-of-3rd-Speed-Gear-6-7hp-Traction-Engines.
          Cylinder-for-6-7hp-Single-Traction-Engine.
          Cylinder-Cock-Gear-for-6-7hp-Comp-Traction-Engines.
          Crankshaft-Second-Motion-Shaft-Bearings-6-7hp-Traction-Engines-red-lined.
          Connecting-Rod-Piston-and-Crosshead-for-6-7hp-Single-Traction-Engines.
          Con-Rods-Cross-Heads-Pistons-Rods-for-6-7-8-10hp-Traction-Engines.
          Con-Rod-Piston-Crosshead-for-6-7hp-Traction-Engines.
          Compound-Cylinders-for-6-7hp-Traction-Engines.
          Class-A-Governor-for-6-7hp-Traction-Engines.
          Canopy-Full-Length-Arrangement-Details-6hp-Traction-Engine-Large-Boiler.
          Boiler-for-Special-6hp-Compound-Traction-Engine.
          Bearings-for-6-7hp-Spring-Traction-Engines.
          Balance-Weights-for-6-7hp-Compound-Traction-Engines.
          Auxilary-Valve-for-Compound-Tractors-Tractions.
          Automatic-Shop-Details-Nuts-Bolts-Pins-and-misc-parts-for-6-7hp-Traction-Engines.
          Ashpan-Damper-Gear-Arrangement-6-7hp-Traction-Engine.
          Arrangment-of-Platform-Ladder-6-7hp-Traction-Engine.
          Arrangement-of-Single-Cylinder-Spring-Mounted-Road-Locomotive.
          Arrangement-of-Reversing-Gear-6-7hp-Traction-Engines-Colonial-Type.
          Arrangement-of-Piping-for-6-7hp-Single-Compound-Traction-Engines.
          Arrangement-of-Pickering-Governor-6hp-Single-Cylinder-Traction-Engine.
          Arrangement-of-Patent-Spring-Mounting-for-Traction-Engines.
          Arrangement-of-Mechanical-Lubricator-6-7hp-Single-Cylinder-Traction-Engines.
          Arrangement-of-Lubricator-for-6-7hp-Comp-Traction-Engines.
          Arrangement-of-Geared-Down-Pump-for-67hp-Comp-Traction-Engine.
          Arrangement-of-front-Tank-Steerage-6-7hp-Tractions-Road-Locos.
          Arrangement-of-Compound-Road-Locomotive.
          Arrangement-of-Boiler-Mountings-for-6-7hp-Traction-Engines.
          Arrangement-of-Boiler-Fittings-6-7hp-Traction-Engines.
          Arrangement-of-8×12-Direct-Ploughing-Engine.
          Arrangement-of-5hp-Compound-Traction-Engine.
          Arrangement-of-3-Speed-Gear-for-Traction-Engines.
          18inch-Wide-Hind-Road-Wheels-for-7hp-Traction-Engine.
          3rd-Motion-and-Hind-Axle-Bearings-for-6-7hp-Traction-Engines-Without-Springs.
          2-Speed-Clutch-Gear-for-6-7-8-10hp-Traction-Engin
          #634995
          Tom Antell
            @tomantell22118
            As well as the drawings I can supply digital copies of any works photographs or restoration photos of 6 and 7hp Traction Engines.
            The price is £120 including postage. Please PM for more info.
            #634996
            Tom Antell
              @tomantell22118
              #634998
              Tom Antell
                @tomantell22118
                #635000
                Tom Antell
                  @tomantell22118
                  #635001
                  Tom Antell
                    @tomantell22118
                    #635002
                    Tom Antell
                      @tomantell22118
                      #635003
                      Tom Antell
                        @tomantell22118
                        #635004
                        Tom Antell
                          @tomantell22118
                          #635005
                          Tom Antell
                            @tomantell22118
                            Above is a selection of some of the drawings on offer, and a selection of all the different 6&7hp traction engine models you could potentially make from these drawings.
                            #635023
                              Tom, suggest you use the For Sale Classifieds not the forum to sell things.
                              #635130
                              Tom Antell
                                @tomantell22118
                                Thanks Jason, Im new to this group and didnt notice that area
                              Home Forums Traction engines Topics
