Rob Roy Build/ Rally
Home Forums Locomotives Rob Roy Build/ Rally
Viewing 4 posts - 51 through 54 (of 54 total)
  • #596869
    Phil H1
      @philh196021
      Rex, Thanks for the prompt answer. If yours has lasted 30 years, that is good enough for me. I'll skip the case hardening.
      I can fix some of the parts. For example, the expansion links are gauge plate and were noticeably hard. I heated up to bright red and cooled as slowly as possible before drilling the various holes in them. They are both now harder than the other mild steel parts but I suspect less brittle than they were. I will leave them in that condition and use gunmetal or bronze for the die blocks rather then the suggested mild steel.
      Hmm – not that far from a running chassis excluding the pumps.
      Phil H
      Phil H1
        @philh196021
        I have a question about the Rob Roy ashpan. I bought, the stainless steel, laser cut ashpan from ME laser. The drawing has a dump pin to allow the ashpan to drop but it looks like it will be a very tight awkward fit – specially around the rear axle. So my question is really how easily the pan drops out and if I fit the boiler, can the ashpan really be slotted up into position whilst the rear axle is in place?
        Thanks.
        #656113
        Rex Hanman
          @rexhanman57403
          The short answer is it's a pain! With the pin pulled out I have to poke and prod it with the pin to get it to drop.
          That's the easy bit, getting it back in is worse. I have found the easiest way to get it back in is to lay the engine on its side on a towel. Insert the firebars and then wiggle the ash pan back in until the pin can be inserted.
          I can't see an easy way to improve things. You will probably need to cut lots of holes in the side and front of the ashpan to improve the air flow.
          #656164
          Phil H1
            @philh196021
            Thanks Rex, sounds like fun. Ian did warn me about Rob Roy maintenance issues at the rally but I bet that most of the other engine designs are a bag of maintenance delights also.
            Phil H
          Home Forums Locomotives Topics
