RLE Engine
RLE Engine
Home Forums I/C Engines RLE Engine
  • #41776
    Dougie Swan
      @dougieswan43463
      Can anyone tell me if the castings that used to be produced by Alyn Foundry are being made by anyone else?. The information I have is that they are now out of business, is this correct?
      Thanks
      Dougie
      Dougie Swan
        @dougieswan43463
        #41780
          I did see a post on another forum about a year ago that one of the ME traders had bought all of Alyn Foundries patterns but have not heard or seen anything since. In the end I built this from scratch with a couple of Stuart flywheels.
          Jason
          #41782
          Dougie Swan
            @dougieswan43463
            WOW, thats a neat engine, is it made from home made castings or is it built up?
            Thanks for the info on the chain
            Dougie
            #41783
              Its all fabricated with teh exception of the two 7″ flywheels which are available from Stuarts. Mechanically its based on a “Zero-six” engine, the plans for which were published in Model Engine Builder Magazine but I did not like the “bar stock” look so made a few alterations inspired by the look of the Galloway Hit & Miss engines.
              Jason
              #41787
              David Clark 13
                @davidclark13
                Hi There
                I heard Chester bought thepatterns but am not sure if true.
                regards David
                #42031
                steamdave
                  @steamdave
                  Alyn Foundry ceased trading from April 2008 for various reasons.  Graham Corry still retains the patterns and drawings for the designs (although not all the designs were drawn up).
                  The business was/is up for sale, but the asking price was a bit unrealistic considering today’s economic climate.
                  As far as I know he has no stock of any castings for his engines.
                  The Emerald Isle
                  #42310
                  Mike DiGirolamo
                    @mikedigirolamo29561
                      I am particularly interested in this topic since I’ve acquired the estate of a master craftsman who recently passed away.  Included in his inventory was a partially completed R.L.E. engine (Serial #290).  I am missing the engineering drawings and a few pieces.  The engine base,  main frame, cylinder and water hopper are all there and mostly machined, as well as the two flywheels.  Although I am still carefully unpacking the shop boxes, but have not found the cylinder head, etc.
                      If anyone has suggestions of where I might obtain the engineering drawings or remaining castings, I’d be grateful.
                    Mike DiGirolamo
                    Charlottesville, VA USA
                    #42312
                      I think the build was covered in Engineering in Miniature, this would have had the drawing in it, you may be able to pick up back issues on e-bay or order them from the publishers. I’ve got the first one somewhere so will dig it out later and give you a date.
                      Jason
                      #42313
                      Mike DiGirolamo
                        Hi Jason,
                          Info regarding the pub date would be greatly appreciated.  I have several back issues of EIM filed away.  I’ll also begin a search.
                        #42314
                        David Clark 13
                          @davidclark13
                          Hi There
                          Construction was in Model Engineer.
                          Probably by Stan Bray.
                          regards David
                          #42318
                          Mike DiGirolamo
                            Hi David,
                              Thanks for your reply to my posting.   It is indeed unfortunate that the online index of Model Engineering is not currently available.  I will continue to search for the article by whatever means I can find.  I wish I could get my hands on a hard-copy of the engineering drawings.
                            Mike DiGirolamo
                            #42321
                            MichaelR
                              @michaelr
                              Mike, Have a look at this site regarding the RLE it gives a good account of a complete rebuild of the RLE lots of pictures.
                              #42322
                              AndyP
                                @andyp13730
                                The R.L.E. was indeed a Stan Bray series, odd number issues of ME from 3909 to 3929 inclusive, which span volumes 167, 168 and 169, volume 167 being the second half of 1991.
                                There are several online sources for an index to ME, the one I use is at http://www.colinusher.info/
                                Cheers, Andy
                                #42325
                                  I stand corrected, it was in ME starting No 3909 Vol 167 15th Nov-5th Dec 1991
                                  Jason
                                  #43481
                                  Engine Builder
                                    @enginebuilder
                                    Hi All
                                    I have the drawings and the ME mags if anyone is interested.
                                    David
                                    #65037
                                    paul whitehouse 1
                                      @paulwhitehouse1
                                      hi i have a complete set of castings from alyn foundry r.l.e and drawings including ammendment sheet info if anyones intrested in them ring 01377 271770
                                    Home Forums I/C Engines Topics
