I've made many customisd rivet snaps from round steel bar, silver steel or BMS will do. Make a dimple in the end of the bar with a drill, heat to bright red, place over a suitably sized ball bearing and bash the end of the rod with a hammer. If you wish, put in the lathe and taper the end neatly.
The local bicycle shop used to sell packets of small ball bearings in many sizes.
