STK,
On the 836 mill, I had to change the plastic fine feed handle to a metal one more to my liking, other than that, in over 2 years of hardish use, I had to do a £2 bearing change that took ten minutes. The bearing hadn’t failed, I just thought it wasn’t smooth enough to my liking. That is it for the mill, it needed no adjustments at all when it was delivered, and I haven’t needed to do any since. Just pump the auto lube every now and then, and give the spindle a bit of oil at the start of the day.
I did fit a 3rd axis to the DRO and a second Z axis readout to the quill, and the usual thing, you don’t even look at the feed handles, it is all done by DRO settings, which are super accurate. I used the spare 2 axis readout on the lathe, so I now have DRO readouts on the compund and tailstock as well as the normal ones.
The lathe, much of the same thing, but I adjusted the ways to my ‘feel’ and did a couple of mods that aren’t really required, just getting the machine more to my liking. I did have the capacitors in the motor fail after about 6 months, but instead of sending me the caps, they sent me a complete new motor. It came the next day, took about an hour to change (I had to drag the lathe out from the wall) and has been running perfectly ever since.
I did have Chester do a few mods for me before delivery, a larger chip screen and removal of the leadscrew guards, mainly because I used to do a lot of faceplate work, and those two as supplied bits cramped my style a little.
As for Chester UK. I personally can’t find fault in their after sales service, and I have been using them since their ‘tin shack’ days on the outskirts of Chester, and they have always sorted things to my satisfaction.
In the early days, the machines were a bit rough but functional (most of the time), but nowadays, their quality control has improved dramatically, but you won’t find any body filler or thick coats of paint to cover up casting imperfections, what you see is what you get, still a bit rough in places, but that is just cosmetic. Paint doesn’t cut metal, the machines do that, and for me, very well indeed.
I let the lathe spindle warm for ten minutes at the start of the day, and once the job is set up, it will hold to 2/10ths all day, time after time, and if you get the DRO option like I did, I don’t even look at the machine dials any more, put a thou cut on using the DRO, and it takes a thou off (or 2 thou, depending on how you set up the DRO).
Bogs
