RINA hit and miss gas engine
Home Forums I/C Engines RINA hit and miss gas engine
  • #73518
    Ian Hall
      @ianhall61297
      I am building a RINA hit and miss gas engine but need help with the following;-
      1 What is the pitch of the 10mm spark plug thread inthe cylinder head.
      2 What is the grade and reach of the spark plug.
      3 What is the valve spring detail.
      4 A flywheel supplier and thier dimensions.
      Thanks Ian Hall
      Ian Hall
        @ianhall61297
        #73519
        David Clark 13
          @davidclark13
          Hi There
          This is the third Rina thread.
          I suggest you check the other two.
          Search for Rina using the box above.
          I think we covered the spark plug.
          The Flywheels are from Stuart models in Guernsey.
          regards David
          #73527
            M10x 1.0mm spark plug thread, the CM6 is the usual plug on most of teh hit & miss engines.
            RDG also have some reasonably priced flywheels
            J
          Home Forums I/C Engines Topics
