Dear Moderators,
I’ve just been booted off this thread, despite having logged on as usual. Will this problem be allowed to persist? It’s not the first time either.
Anyway, those are interesting and quick responses from you chaps. Thank you.
All of this seems to have stemmed from the fact that the early British rail layouts had to go around the hills rather than over the top. The engines were not powerful enough to haul heavy trains up steep hills. Am I right?
I don’’t have access to ME of any volume, so I’’m unable to follow through with KWIL’’s comment, but thanks anyway. And `Tomorrow’s World’ certainly is a possibility, but Oh so long ago.
At the beginning of this thread, I should have added that (as I recall), the steering system had a hydraulically powered output, but not sure how they sensed the input details.
I’ve pondered the idea of self-aligning wheels, and rolled back-to-back cones turned from bits of bar down the track when my children (and I) had an `N’’ scale layout. Nevertheless, I hadn’t heard of it being referred to as `tyre coning’’. Considering the probable negative issues from coning, although initially more costly, a powered system appears to offer more merit.
For a viable system, a few questions immediately come to my mind. In particular :-
a) A truly conical back-to-back profile is unstable so, can the instability (hunting) be fixed by machining a mathematical profile? I would imagine, YES!
b) While the profile of the tyres might be machined to a particular (mathematical) formula, (a bit like the bias on lawn bowls), will/does the profile last for a respectable enough time before it needs re-machining?
c) And what about the surface of the rails? Wouldn’t they need frequent grinding, to account for wear and thermo/geological movement?
It’’s certainly a challenging conundrum, and although (I digress), I once (c1970) determined the maths and geometry for the mould-release angles for external moulded threads, rimless wheel geometry would tease my aging mind too much. By the way, from my mould-release calculations, I also concluded that lathe lead-screws and split nuts have to be of an ACME form for the same reason.
As I digress even more, I’’m also reminded of the time when, as a young apprentice, we visited the Horwich Locomotive Works in Lostock near Bolton, and watched as (full size) rolling-stock wheels already attached to their respective axles, were being machined. And, being further mesmerized, watched as the very hot tyres were being shrunk on to the wheel cores.
Regards to all,
Sam
