Hi there, all,
Here's a minor item from the first photo:
I believe that the gizmo with the black drum is called a 'Kymograph'. It's used by botanists or botany students to measure the growth of plants. That would fit in with the RHS connection. I'm no botanist but, to the best of my recollection, you wrap a sheet of smoked paper around the drum and position the gizmo next to the plant under test. There's a clockwork motor inside the drum that rotates it at a known rate. A stylus attached to the plant bears on the drum and leaves a trace on the soot coating from which the rate of growth of the plant can be deduced. (In high CO2 levels, they grow higher and faster.)
The smaller clear object in the bottom right-hand corner of my photo is a spirit lamp. It wouldn't have been used (on its own, at least) to smoke the kymograph chart since a spirit lamp gives a smoke-free flame. In my early days of at-home chemistry experiment (in my bedroom) I used one in lieu of a Bunsen burner.
My grammar school chemistry master gave me an out-of-date catalogue from a scientific supplies firm, Townson & Mercer Ltd. of Croydon. It was even bigger than the last hard-bound Buck & Hickman catalogue, not quite a fork-lift job but pretty weighty. Browsing through it raised lots of questions like 'Please sir, what is a Kjeldahl's apparatus used for?'. An extra-curricular educational supplement!
On the subject of mirror galvanometers, with ribbon suspensions, my Senior Engineer in my first job preferred H. Tinsleys of Werndee Hall in South London. (I can't remember their full address.) I once had a guided tour of the Tinsley factory. They did some quite clever stuff with 'galvos' with multiple coils and connecting ligaments to measure power et. al..
Best regards,
Swarf, Mostly!
Edited By Swarf, Mostly! on 29/12/2021 17:12:08
