Return key
Return key
  • #121662
    Packmule
      @packmule
      When posting I can't get the return key to work to create a new line or paragraph. Driving me mad …….angry bob
      Packmule
        @packmule
        #121666
        Steambuff
          @steambuff
          As per other posts on this subject …. Switch Compatability mode on.
          Then the 'Return' Key works
          Packmule
            @packmule
            Brilliant Thanks Dave, sanity restored
            I only had trouble with this site , so is it microsoft or M.E ?
            Cheers Bob
            #121673
            Steambuff
              @steambuff
              Bob,
              I think is is a bit of both … The site for not obaying Microsoft Standards … and Microsoft for imposing its own standards.
              Russell Eberhardt
                @russelleberhardt48058
                Posted by Steambuff on 06/06/2013 13:36:42:
                Bob,
                They are not Microsoft standards. Microsoft is just one member of the World Wide Web Consortium which is constantly developing the standards for web pages. Unfortunately Microsoft doesn't always follow the standards they help to write sad
                Russell.
                #121685
                magpie
                  @magpie
                  The return key will not work for me unless i use the compatability button, but when i do that the text disapears behind the ad's, so i can't win either way.crook cheers Derek.
                  #121692
                  dcosta
                    @dcosta
                    Hello Bob (Packmule).
                    To create a new line you can use simultaneously the Shift key and the Return Key.
                    If you use the Return key alone you insert also a new empty line.
                    If you want to create an empty line just do Shift+Return tywice.
                    Best regards
                    Dias Costa
                    Edited By dcosta on 06/06/2013 18:15:41
                    #401257
                    Speedy Builder5
                      @speedybuilder5
                      Has the forum site been improved, The RETURN key now works on Apple Mac "Mojave" instead of using Shift Return.
                      BobH
                      #401262
                        Posted by Speedy Builder5 on 19/03/2019 18:11:58:
                        BobH
                        Yes.
                        As for teh earlier question Microsoft or ME… Microsoft didn't add a compatibility button because their browser doesn't work with this website, it was because it doesn't work with thousands of websites. Nuff said?
                        mechman48
                          @mechman48
                          Posted by dcosta on 06/06/2013 18:15:24:
                          Best regards
                          Dias Costa
                          Bob… Always had to do the same on this forum, raised the question with moderators last year but never really got to the bottom of it. Still have to use the same method as Dias above. never have any probs on any other forum.
                          George.
                          #401270
                          V8Eng
                            @v8eng
                            Return now gives a single line spacing in IOS12 that’s a great improvement,  it always used to give double line spacing.
                            Edited By V8Eng on 19/03/2019 18:38:40
