So, couple of people have asked me if I would put this all into one thread – Here Goes!
Some months ago I realised that my ageing – bought by myself new twenty odd years ago – Nu-Tool drill press needed replacing. One of my main complaints was the rather useless circular table. I have no idea who designed a drill press with a circular table but believe me they are a nightmare to clamp anything to. I determined that the replacement would have a "good" table. There were other issues but I will concentrate on the new drill.
I had a good look around and they ranged in price from a few pounds to new car prices. I had determined that what I wanted was either a Meddings a Fobco or an Elliot – there are exotics but I thought it best to stick with something mainstream and more importantly something that spares wouldn't cost the earth.
As is always on the "online auction sites" collection only ensures the price is realistic or even Bargain Basement – at 135 odd kilos you just can't post one. So I looked around within a fifty mile radius and this Elliot made an appearance.
I had to put it in the car in bits because there was no way I could get the thing out in one piece!
Next thing was to have a real close look at what I had:
The castings are in excellent condition with no wear, this drill had been in a "farmers workshop" for a long time so it hadn't really seen much use for a good many years. There must be thousands of useful pieces of machinery like this lying around the countryside all replaced by "Modern" equipment.
There are six bearings in the drill and they are all pretty standard stuff, easily obtained – especially if you know what you are looking for
I sent all of the castings off to Roy who "does shotblasting" with the exception of the main head casting. This was full of vintage grease – caked on. The only way to get rid of this really is to submerse the thing in Cellulose thinners, or the cheap stuff, Gunwash, that the paint lads use to clean up with. This is not for everybody but I use a good deal of it, we are old friends, and I cut the top off a five gallon container, put the head in it and filled it with Gunwash. I let it soak for a couple of days and put it on the bench. An hour with a rotary wire brush on the Angle Grinder and we had this:
The table had a bit of decorative drilling applied so the holes were filled with a bit of weld, nothing special just a bit of Mig wire. On reflection I am wondering about this as if there are any marks in future there can only have been one culprit! Seen here after the paint was applied:
I picked up the castings, masked them all off and gave them all a coat of high build primer:
Meanwhile, all of the fittings had been sent off to be restored, my friend does a really good Chrome and Blueing job, mainly because he does excellent preparation:
The column was chucked in the lathe and polished, then I scored a good deep line down it. This will give me a reference mark. How many times have you wondered whether or not the drill bit would clear the hole?
I brush painted all the bits, three coats of Tekaloid Enamel, and the finish is, as always with quality paint, excellent! I didn't flat down between coats, I applied the paint quite heavily and let it flow and didn't let the previous coat quite cure.
