We had some resin laid at the back of our house to tidy up a nasty concrete area. Actually several of us in the terrace contributed.
The job looks good, but it appears that they've got some resin down one of our drains and it's clogged. This is fed from the utility room and a flat roof so at the moment getting quite some water.
The chaps who did it said they would come back Friday, then today and … the drain is still blocked.
How would I clear resin from a drain? My thought was to scoop out and dry the drain to see what is happening then to set to to drill some holes, one of those reciprocating saws and a gently applied 4 lb lump hammer and chisel.
Seems hard work and likely to damage the drain…
Is there an easy / lazy way to sort this out?
Many thanks
Iain
