Hello,
I’m a long-time reader but first time poster. After a long wait, I am finally the happy owner of a Stuart Model 800 I/C engine. There are several things I am curious about in the case of my particular engine.
-First, the configuration of the ignition system is different to what I have see on all of the other 800’s I have found on YouTube and other sources. Does the system on mine in the photos below look like one of the options available from Stuart or could it be a separately sourced solution?
– Also, mine has a cast aluminum carburetor on it, whereas in all other 800 engines I have seen, this carburetor is not used.
– And third and lastly, I have not been able to determine when Stuart ceased producing these model 800 S. If anyone has inside to that I would be most appreciative as well.
Thanks for any help!
Ninev
