I have had to do this for a 7 and S7, and confirm it is not a trivial job, especially if you intend to fit a new shaft. Hammering them in, using G clamps etc is not recommended, oilites will distort in a heartbeat.
You absolutely do need to make up a pulling mandrel, find lengths of threaded bar and have some appropriately sized tube washers and nuts to use as pullers.
Your mandrel should be stepped to conform to the exact external diameter of the shaft (avoid being smaller) with the wider portion say 10 thou less than the id of the bearing recess. The part upon which the bearing sits needs to be slightly (4-5 mm) longer than the bearing. Tap the mandrel for 8 or 10mm threaded pulling rod.
Pulling the old bearings out is easy, pulling the new ones in needs a bit of care on the initial alignment. Soak bearings in oil and use lots of oil when placing bearing on mandrel (it may be tight)
You may need to wring the mandrel back out of the bearing, or even need to pull it out.
My nasty experience came when I discovered the new shaft was a wringing fit in the new bearings. I tired slow running the shaft as a bearing run in, but it was clear that it was seizing.
Now here is the thing, you don't want to ream this type of bearing and even if you did, how would it be possible to do it accurately in situ? I solved this problem by making up a polished olive that was a couple of thou bigger than the shaft id. This is pulled through the tight bearing making it conform to the required size (process may have to be repeated). These bearings have a porosity, so within reason can be 'squeezed' to size.
Eventually, the shaft fitted albeit a little tight, but easily enough that after a bit of running in, all was well. The running in consisted of: run the shaft at min primary speed, as soon as the bearing gets cup of coffee hot, say over 50 C. stop and allow to cool. Repeat until happy that the heat build up is reducing.
With the lathe back in service, keep bearings well oiled and monitor temperature, ceasing operations if getting too hot until well bedded in. A year or so after fitting, my countershaft bearings get just slightly warm after a couple of hours run. I make sure the oil cups are full before every use.
