Replacement heater switch
Home Forums Electronics in the Workshop Replacement heater switch
  • #382943
    Dave C
      @davec87625
      Not strictly workshop heating however my daughters electric heater broke today. The rocker switch rocks loosely with no positive locking in either position.
      I have the details and have searched the web but cannot find an exact copy matching the details on the original switch without slight differences in Amperage one way or another.
      I need a KCD3 ENC1
      16A 250 VAC, 10A 125 VAC T105
      I can find 16A 250VAC but then only 20A 125VAC.
      It appears the original switch is just broken internally and so I am hoping a direct replacement will do the trick.
      Would anybody know of a source for a replacement or best to leave well alone. The switch is approximately 10 x 25mm where inserted with 3 spade connections.
      There is a small light on the switch also.
      Many thanks
      Dave C
        @davec87625
        KCD3 rocker switch
        #382948
        Emgee
          @emgee
          Dave , the 16A 250vac switch you have found will be a suitable replacement.
          Emgee
          #382952
            Hi Dave,
            As you are UK based any 16A 250VAC rated rocker switch will be suitable.
            That is a standard size (originally 1" x 3/8&quot illuminated or not and you should be able to find one.
            Former Member
              @formermember19781
              #382978
              Dave C
                @davec87625
                Thanks guys. Switch ordered. Daughter happy.
