Hi Tim.
I had the same issue with the nose bearing on my lathe motor, fitted to a Myford. I tried to find an ‘off the shelf’ replacement but was unable to find one. I then took it to my local rewind specialist who then refused to do the job. He doesn’t repair motors with plain bearings.
I was fortunate in that I had access to another lathe, so ended up making one out of phosphor bronze, this included a shallow groove in the bore to aid lubrication. I bought a suitable reamer to finish the bore, which was a good decision as I had to ream again on assembly as the bore had closed down (as anticipated). That was more than a year ago – so far so good.
Strangely the ‘old’ bearing had an imperial OD and a metric ID (I think it was that way round, memory not as good as it was), so my assumption is that the motor was manufactured at the time when UK industry was transitioning from imperial to metric.
It’s worth a go if you can get access to another lathe.
Alan.
Edited By Alan Donovan on 30/06/2023 08:14:02
