Repairing plastic hinges
Home Forums The Tea Room Repairing plastic hinges
  • #640037
    Grindstone Cowboy
      @grindstonecowboy
      Hi
      Does anyone have any good tips for repairing plastic hinges? I mean the type that are moulded into the box and flex as you open and close the box. My Mitutoyo dial caliper box is starting to show definite signs of failure and I'd like to catch it before they part company completely.
      As an aside, I'm also going to replace the foam inserts which have completely disintegrated – any tips for what to replace those with?
      Many thanks,
      Rob
      Grindstone Cowboy
        @grindstonecowboy
        Plastic hinges are fatigued – how can I fix them?
        #640041
        John Doe 2
          @johndoe2
          Look up "Shadow foam" for the latter, no connection etc.
          For the former, I don't know but you might try a glue gun, or carefully applied strips of gaffer tape, having thoroughly cleaned the hinge surface first of course.
          #640045
            Foam inserts are best replaced with Plastazote
            [ trade name … ‘clones’ appear to be available ]
            To the best of my knowledge there is no way of repairing a failed Polypropylene hinge … just use tape or add a proper mechanical hinge.
            Bill Davies 2
              @billdavies2
              I've used the green polyester felt from Hobbycraft to line an old steel micrometer case. It's very thin, but cushions the old micrometer. I glued it using contact adhesive.
              Bill
              #640048
              Dave Halford
                @davehalford22513
                You used to be able to get plastic hinges for model aircraft control surfaces maybe they still use them.
                #640054
                Hollowpoint
                  @hollowpoint
                  Perfect opportunity to make yourself a nice wooden box. Oak or walnut, brass hinges and a custom cutout for it to sit in lined with felt. 😎
                  Edited By Hollowpoint on 03/04/2023 13:49:11
                  #640057
                  Ady1
                    @ady1
                    A decent duck tape does those funny ones, cut to shape
                    #640059
                    duncan webster 1
                      @duncanwebster1
                      I thought oak caused steel to rust?
                      #640063
                      Dalboy
                        @dalboy
                        I made this insert to fit into one of my draws, it would be so easy to add hinges and a lid. This was made from mahogany and then lined. You can buy sticky backed felt to line it with to protect the instrument.
                        It was marked out and then a router used to take out material for the micrometer to fit
                        #640066
                        roy entwistle
                          @royentwistle24699
                          Do NOT use oak. The tannin will stain the caliper
                          Roy
                          I noticed Duncan typed faster than me
                          #640067
                          Baz
                            @baz89810
                            Dave Halford is correct about the hinges, there are many types, proper miniature hinges, moulded plastic ones and strips of Mylar film about 20mm wide. Mrs Google will find your nearest stockist,
                            #640087
                            Martin Kyte
                              @martinkyte99762
                              I think it’s the oxalic acid in oak that induces corrosion.
                              regards Martin
                              Some plywoods do to.
                              Edited By Martin Kyte on 03/04/2023 20:34:31
                              #640088
                              Tim Stevens
                                @timstevens64731
                                There is no cure for fatigue. Once the failure has started, there is very little chance of repair – except renewal, which is not repair sensu stricto ( or should it be senso strictu?). The problem is that fatigue works by extending a crack – and the crack is the source of further failure. It may be possible, in some cases, to remove the crack completely including the material on both sides, and filling the space with new material which is integrated (not just glued or stuck) into the original. Perhaps possible with a steel component restored by welding, but even then there are likely to be future problems with the weld not being the same as the original metal, or the heat of the weld affecting the condition of the surroundings in various ways.
                                A cloth hinge, if you can manage it, is likely to last at least as long as the original plastic. But the glue might not.
                                Cheers, Tim
                                #640094
                                Grindstone Cowboy
                                  @grindstonecowboy
                                  Thanks chaps, all useful info as usual. I think I've found an equivalent type of foam and some wing hinges on Amazon. Might just try some Gorilla tape in the interim and see how that goes on the hinges.
                                  The wooden box idea will go on the "to do" list, though!
                                  Thanks again.
                                  Rob
                                  #640096
                                  John Doe 2
                                    @johndoe2
                                    Plastazote looks good, but you will need special tools to cut it cleanly and uniformly at varying depths. Shadowfoam is designed for the person without such tooling, yet still provide a professional looking result. It is made from many layers of material that are bonded together but cleanly separate at the depth you require, once you have cut the outline of the item into the foam.
                                    #640110
                                    Emgee
                                      @emgee
                                      If you have any old and unused 3.5 inch floppy discs you can open them up to use the disc material as a hinge, work a treat.
                                      Emgee
                                      #640130
                                      John Haine
                                        @johnhaine32865
                                        I made a collet box for ER16 collets by CNC machining in a block of MDF, with a matching block that sits on top to "close" it. To reinforce the material and proof it I soaked it in several coats of Ronseal wet rot treatment – this is a penetrating "lacquer" that soaks into the material and dries and hardens. Not sign of any corrosion after 10 years. May work on other woods too.
                                        #640134
                                          Posted by John Doe 2 on 03/04/2023 22:10:22:
                                          For what it’s worth … Plastazote cuts very cleanly with a knife, or with a sharp-edged tube
                                          [but yes, to make a flat-bottomed recess, you would need to glue layers together]
                                          The reason I particularly recommend it though, is its widespread use in modern military packaging …From personal experience testing such stuff; I think it is probably the available material that is least-likely to degrade with age or climatic cycling.
                                          martin haysom
                                            @martinhaysom48469
                                            i have the same problem. one day i will make a new box. from pallet wood
                                            #640274
                                            Anonymous
                                              Posted by Grindstone Cowboy on 03/04/2023 12:07:03:
                                              You're the one staring at the actual article of course, Rob, but it might not be as bad as you think. I have a daily pill reminder with 7 compartments that I've used continually since 1986. I expect many here have too. I remember wondering at the time how long the 'living hinges' (what the artsy designers called them at the time) could last. But none of the seven has failed in all that time though they've "showed signs of fatigue" for years.
                                              #640287
                                                Posted by Peter Greene 🇨🇦 on 05/04/2023 18:16:06:
                                                I worked at KODAK in the early-mid 1970s, and we were using such hinges on the backs of the little 110 cameras: It was soon convincingly demonstrated that it matters A LOT how soon after ejection from the moulding machine the hinge is first flexed … Get it right and they last for ages, but let it cool too much before that first flex and the hinge is doomed to fail.
                                                Trouble is … the end user doesn’t know whether they have a good ‘un or a bad ‘un.
                                                Anonymous
                                                  Interesting, Michael, and makes sense to exercise the hinge while the material is still partly plastic. For small volumes the hinge could probably be closed by the operator upon ejection from the core, but I wonder how they could automate it for large volumes such as pill containers.
                                                  #640825
                                                  Grindstone Cowboy
                                                    @grindstonecowboy
                                                    Hi chaps
                                                    Sorry for the delay in replying, been away on holiday.
                                                    It's a genuine Mitutoyo, but unsure of the age as I bought it at a car show many years ago. One of the three hinges is definitely parting company. Not sure if age or storage conditions have a bearing on it, but I can see that the box has bowed slightly so the axis of the hinge pins (for want of a better description) is not a straight line. I guess that puts extra stress on it.
                                                    Rob
