Thank you for the above advice, it is very helpful
I have repaired other part of the crankcase using brazing but had trouble stopping the flux from burning ( pure borax )
The explanation about the carbon above explains why I could melt the rods but it just pooled
If I cut a vee along the crack and then followed the advice about heating and cooling before cleaning and fluxing then it might work
This is a water jacket on a single cylinder Aster engine that has been split by frost, it has a number of previous attempts at repairs, some welded some soft solder, I want to remove traces of these and have a relativly smooth finish
I have also thought about trying the epoxy route I mentioned above. Would the likes of JB weld be flexible enough to take the thermal expansion, perhaps with some kind of sealant applied to the inside of the very rusty inside?
Thanks
Dougie
