My scroll wheel started acting up. Might jitter about in any direction but one thing it wouldn't do is scroll. As in the past I have worn loads of keyboards out working on software at home I still buy Cherry. Logitec key markings wear off and the usual HP stuff breaks – their workstation ones are great but not wireless. The mouse is about 2 years old and I would expect a longer life than that even doing rather a lot of photo editing at times.
Thought it might be software so googled for ideas and found mention of dust and bits of fluff. I used a duster can to blow down each side of the wheel. Bit of an improvement so I dismantled it and gave what looked like some sort of encoder a good blast. Even better. Next came IPA on a thin paint brush. On the bit that the wheel turns and a bit of excess to run down into it – then another blast to blow the IPA away.
It's working perfectly again. Saves me spending £60 ahead of time as replacement mice for the 8000 set don't seem to be available.
It seems many mice are held together in a similar way. I screw under the batteries and in this case 4 more under the pads. A chunk of metal in this one as well to increase the weight.
I wondered about putting this in workshop equipment but then thought not.
Edited By Ajohnw on 31/08/2016 23:25:21
