repainting powder coated metal ?
Home Forums Workshop Techniques repainting powder coated metal ?
  • #15927
    capnahab
      @capnahab
      capnahab
        @capnahab
        It that time of year and the exterior bits need sprucing up, – railings and garden table and chairs (sheet metal). I know they need to be degreased, clean, dry etc but what about primer and prep ?
        Edited By capnahab on 26/03/2017 12:44:12
        #290712
        Farmboy
          @farmboy
          I repainted a set of powder coated kitchen chair frames. I degreased, rubbed down with wet & dry paper to take the shine off, and used melamine cupboard paint as I thought that might adhere better to the coating. It did appear to work, but after a few months the paint started rubbing/peeling off.
          There may be a paint/primer for the job but melamine paint is not it sad . . . but it is excellent on melamine and vinyl covered doors. Not a very helpful post but it might save some wasted time.
          Mike.
          #290716
          Clive Foster
            @clivefoster55965
            Definitely need the proper primer. Data sheet for Dulux Trade Super Grip primer claims that its suitable for powder coated surfaces after light abrasion. Water based so it ought to be easy enough to get. That said I'd be looking into proper plastics primers with chemical adhesion capabilities. Trouble is not only do you need a good idea what the powder coat material is to select the right one but getting hold of anything other than water based paint is getting harder and harder.
            Clive.
            #290718
            Ed Duffner
              @edduffner79357
              Would Hammerite Smoothrite do the job?
              Ed.
              #290737
              vintagengineer
                @vintagengineer
                Unfortunately powder coating is actually plastic coating. The powder coating industry will call it all manner of names but it is plastic coating. It is the quickest and cheapest way to produce a nice finish that will last as about long as a chocolate teapot.
                The problem with it is as sooner as you damage the surface the moisture gets in and rusts like hell from the inside.
                To paint it you need a plastic primer or an etch primer.
                #290741
                Ex contributor
                  @mgnbuk
                  My local powder coaters bake old coated parts to make the remaining coating brittle before shot blasting the remains off.
                  If you can remove the loose bits mechanically & scuff-up the secure remaining coating, a two-pack etch primer should give a sound base to refinish. International Paints used to do a two pack etch primer for outboard motor bottom units that was particularly tenacious on aluminium castings (I used it brushed on to motorcycle alloy wheels to good effect), but it isn't cheap.
                  Nigel B
                  #290750
                  KWIL
                    @kwil
                    The powder coat paint on my outdoor custom made railings lasted 25 years with only minor problems. Rubbed down and recoated without problem using "self priming black enamel"
                    #290775
                    Brian H
                      @brianh50089
                      One problem is that most powder coating products contain wax.
