Renewed interest in ME
  • #727302
    robmill
      @robmill
      Hello all,
      I came into model engineering in the late 1960’s and built the chassis of a 3.5” Rob Roy tank. I was rather daunted about the boiler, no experience of silver soldering plus the expense being in my late teens and a limited budget the chassis was sold for a very modest price. However this was a steep learning curve and having seen an advert in ME for castings of a 2” Burrell (MJ Engineering if I recall) compound decided to make this my next project. In the meantime I had acquired an old Victorian lathe, 6’ bed length, flat belt drive, but for £10 you couldn’t go wrong……the lathe was perfect and accurate.  Work on the Burrell went well, then it was 2 of us with largest Sievert burners soldering up the boiler…….there were issues, a number of minor leaks around the side stays, compressed air tests showed the model to work. Then with a young family, a move of house that could not accommodate the workshop in the 1980’s the Model Engineering sadly came to an end…..the Burrell was sold and a caravan bought for the children’s holidays. Now moving on……2023, have been a widower for 3 years….time to move on so the urge to return to Model Engineering became very strong so, bought a mini mill and lathe and restarted with a Stuart S50……success….wanted to go bigger……needed a bigger lathe,Warco came to the rescue so Stuart Victoria and beam engine completed and running well under steam.
      Then I saw an advert for the castings of a Galloway’s Non Dead Centre engine, could not resist so this is my latest project.
      I have a winter workshop with smaller lathe and milling capabilities and a summer workshop in the garage with Warco lathe and milling machines.
      Please excuse the ramblings of an old man, but this is what keeps me happy, mind active and sane!!!
      Rob
      Harry Wilkes
        @harrywilkes58467
        Welcome to the forum
        H
        #727324
        noel shelley
          @noelshelley55608
          Welcome Rob, your amongst friends. Noel.
          #727368
          Brian Baker 2
            @brianbaker2
            Good to have you with us Rob,
            Keep turning!
            Brian B
            #727545
            robmill
              @robmill
              Thanks for your welcomes guys…😀
              #727568
              Howard Lewis
                @howardlewis46836
                Welcome to the Forum.
                You are obviously experienced, and will find many like minded individuals on here.
                Keep in contact!
                #727588
                robmill
                  @robmill
                  Thank you Howard
                  Rob
