REMOVING STEEL BOILER TUBES
Home Forums Traction engines REMOVING STEEL BOILER TUBES
  • #496556
    noel shelley
      @noelshelley55608
      Gentlemen, A dear friend has a foster 3" or 4" traction engine he built about 25 years ago. He is not in the best of health and needs the boiler tubes replaced and to that end I have offered to help or do the job. The plan is to machine up a fitting which will fit inside the old tube with a slightly larger diameter to sit on the end of the tube to be removed, though just smaller than the tube o/d. A length of 16mm threaded rod with a nut on it passes through the tube into the smoke box where a section of tube of just larger than the o/d of the tube to be removed is used as a spacer and a hollow hydraulic cylinder on the end retained by another nut is used to pull out the fire tube. The hydraulic cylinder will develope about 5 tons pull. My fear is that if the tube does not move then damage may occur to the tube plate, though there is a pressure gauge on the cylinder so the applied force can be read. Or how else can I get the old tubes out .I have oxy/ propane and am skilled in it's use. Any advice on this job will be a great help. Noel.
      noel shelley
        @noelshelley55608
        #496560
        Brian Abbott
          @brianabbott67793
          Hello, not really any help but there was a write up in one of the ME magazines a short time ago.
          i cannot remember which edition it was but i am sure someone will know.
          If i remember correctly is was over 2 editions.
          #496563
          Martin Kyte
            @martinkyte99762
            Don't confuse me with someone who has actually done this but the full size boys drill them out I think. As far as I can see the principle is the tubes are expanded into the hole in the tubeplate so the holes are larger than the tube diameter to start with. Once the tube has been drilled nominal diameter they should pretty much fall out. I assume they are not welded in otherwise your plan will fail anyway.
            Don't just take my word for it but ask the full size boys.
            regards Martin
            #496565
              The difficulty is getting a drill into our size fireboxes and not having a decent size manhole.
              As Brian says there was a good 2 part article in ME though I think it was a bit more than a short time ago, can't find them at the moment.
              #496566
              Nick Clarke 3
                @nickclarke3
                In ME vol 196 (2002) issue 4267 Dennis Herbert of the Elmdon MES describes the retubing of a 7 1/4" gauge Highlander locomotive with a steel boiler which may help.
                Edited By Nick Clarke 3 on 18/09/2020 19:57:57
                #496567
                Former Member
                  @formermember12892
                  #496569
                    First part was in 4396 by Chris Gunn, second part in 4401
                    Edited By JasonB on 18/09/2020 20:19:32
                    #496570
                    Brian Abbott
                      @brianabbott67793
                      Well found, was a very interesting read.
                      #496573
                      Andrew Tinsley
                        @andrewtinsley63637
                        Having done the full size version on several locos, I can assure you that the tubes do not "just fall out" after drilling. There is a small matter of scale on the tubes and they can be a swine to get out!
                        Andrew.
                        #496575
                        Martin Kyte
                          @martinkyte99762
                          Quarter or Third scale isn't all that smalll Jason. Just a little concerned about the strain on the plates particularly as less and less tubes remain. It must be possible to come up with some rig to drive a cutter in the firebox from the smokebox end a but like counterboring on the underside of a plate with the mandrel passing through the hole. Once most of the tube thickness has been removed it must make it easier to pull out.
                          As I said I haven't done it but it sounds like Noel hasn't either. He is brave to volunteer in my book, but sensible enough to find out all he can first. Best of luck Noel.
                          regards Martin
                          #496581
                          Chris Gunn
                            @chrisgunn36534
                            Noel, I hope you can get a copy of the 2 articles I wrote longer ago than we all think, but to answer your question, I ground the ends of the tubes back to the firebox back plate, so any swelled tube ends were removed. I could get in with a 4" disc grinder to get most of the corner ones. Today i would use a power file as well to get in the corners. At the front I made a bar to fit the tubes, and fitted a boring tool to it, and adjusted it to remove most of the material in the bore just about 1/2" in. I was surprised how easily it cut using a power drill. then I used 16mm studding to pull the tubes out, and they came out OK. However it is easy to strip the studding if you get a tight one. If I were to do it again, like one of my fellow club members this year, I would use a hydraulic puller. It has been a bad year for tubes in our club, a 3" McClaren, a 3" little Samson and a 3" Allchin have all been done more or less this way.
                            Chris Gunn
                            #496589
                            Harry Wilkes
                              @harrywilkes58467
                              Posted by Andrew Tinsley on 18/09/2020 20:37:27:
                              Andrew.
                              Agreed wink
                              H
                              #496591
                              duncan webster 1
                                @duncanwebster1
                                That's why some of them have the front end swaged a bit bigger so that once you've got them clear of the firebox end and a few inches out it becomes a lot easier
                                Edited By duncan webster on 18/09/2020 21:29:18
                                #496593
                                Speedy Builder5
                                  @speedybuilder5
                                  Would it be a good idea to de-scale the inside of the boiler first ?
                                  #496630
                                  Paul Lousick
                                    @paullousick59116
                                    Getting the old tubes out of the boiler can be a real pain. Done it on a couple of full size engines with 1 1/2" and 1 3/4" diameter steel tubes.
                                    The end of the old steel tube was cut from inside of the tube and just behind the tubeplate at the smoke box end with a plasma cutter (or oxy cutter) taking care not to damage the tubeplate. (suggest using a Dremmel with a cutter disc for small tubes). The stub end than removed by crushed with a chisel and hammer.
                                    A length of pipe then inserted thru the smokebox tubeplate and boiler tube to sipport it while the tube end in the smokebox was also crushed with chisel and hammer and the tube withdrawn thru the smokebox end. The pipe used to guide it thru the hole.
                                    Holes in the tubeplate are normally a clearance fit with the tube and with a bit of pushing and pulling it is possible to scrape off any scale on the tubes and remove them from the boiler.
                                    A possible problem which you could have with just trying to remove the tubes with a hydraulic puller is not only the force on the tubeplate but if they buckle behind the tubeplate inside of the boiler.
                                    When I built my boiler, I added a large inspection hole in the tubeplate at the firebox end. Then all I have to do is to cut the tubes at both end inside of the tubeplates and slide the old tubes thru the inspection hole. And remove stubs in the tubeplates.
                                    Paul.
                                    #496642
                                    Martin Kyte
                                      @martinkyte99762
                                      I'll bow out now there are commentators with more expertese than me posting.
                                      (Whilst it seems they won't just fall out after drilling just trying to hydraulic them out is fraught with danger).
                                      regards Martin
                                      #496682
                                      Chris Gunn
                                        @chrisgunn36534
                                        I had a couple of tubes crumple as they came out, if one uses a mandrel that is as good a fit as possible in the bore this stops the tube crumpling. Then one must make a drift and knock the bent tube back in the boiler, and hook it out of the mud hole, and cut bits off it untll you can get it all out.
                                        Noel do not be put off, it can be done with patience. However if you are not happy to have a go there are folks out there who will do it for you, at a price of course.
                                        Chris Gunn
                                        #496688
                                          Quick question for those that have replaced tubes. Does the boiler then need a 2 x WP test and if so do all fittings need to be removed for that and plugged? Then the usual 1.5x WP with it back together and an accumalation test or just the 1.5x?
                                          #496689
                                          Nick Clarke 3
                                            @nickclarke3
                                            Posted by JasonB on 19/09/2020 13:18:27:
                                            Jason – as I am neither your, nor the OP's, boiler examiner I cannot give an authoritative answer but the current test code states –
                                            "Any structural modifications shall invalidate the initial shell test and necessitate a re-examination and re-test at TWICE Working Pressure (2xPW) for both copper and steel boilers"
                                            and subject to another opinion from your tester I should consider re-tubing a structural change as the tubes will provide support to the smokebox and firebox tubeplates.
                                            #496694
                                            Pete White
                                              @petewhite15172
                                              I was wondering how you might repair any accidental damages the tube plate holes ?
                                              #496704
                                              Paul Lousick
                                                @paullousick59116
                                                Pete,
                                                Depends on how much the holes were damaged. Small nicks or grooves can be smoothed by reaming or grinding the hole slightly larger. Roll type tube expanders easily enlarge the ends of the tubes. On one of the boilers that we overhauled with 1 1/2" tubes, some of the tube plate holes were 2 – 3mm oversize and they sealed satisfactory for a 180 psi ticket. Larger grooves have to be welded and re machined.
                                                Cannot remember if test was 1.5x or twice WP. A tube failure is not catastropic and the boiler will not blow up, just leak.
                                                Paul
                                                Edited By Paul Lousick on 19/09/2020 14:22:09
                                                #496711
                                                duncan webster 1
                                                  @duncanwebster1
                                                  I very much doubt a model has these, but some boilers have stay tubes which are welded both ends. These are definitely structural
                                                  #496766
                                                  noel shelley
                                                    @noelshelley55608
                                                    Firstly many thanks to all who have offered advice or comment. This work is being done due to a leaking tube and will be followed by an internal boiler inspection, followed by re tubing and what ever else the inspector wants. The tubes are 25 years old and one of my fears is that they will just fold up and how to get them out if this happens. The hand hole is not large !!! Even if I cut the ends off I still have to get all the bits out. I want to avoid any damage to the tube plate holes. One thought is an expanding reamer on the smoke box end to thin it, collapse whats left and then use the hydraulics to pull the fire box end and tube out having ground it back to the tube plate first ?
                                                    best wishes to all, Noel
                                                    #496798
                                                    Chris Gunn
                                                      @chrisgunn36534
                                                      Noel, an expanding reamer will not take much out, much quicker to make the boring bar I mentioned, and bore 1/2" back. you can do it in one cut if your tubes are 1/8" thick, leaving a 10 to 15 thou wall for example. I did some research before trying the method I describe in my article, it seemed half pulled the tubes out from the front, and half knocked them through into the firebox. Some folks I know worked on a 4" Foster, and knocked the tubes from the front into the firebox, and cut a piece off, and repeated until the tube is fully out. it is a 2 man job, 1 to hold the drift, and one to wield the sledge hammer. This seemed rather brutal to me, very hard work, and was quite time consuming, 2 or 3 tubes an evening if all went well. unless one makes a series of drift/mandrels it is not possible to support the tube internally as it is driven through. The chance of damaging the front tube plate seemed higher to me that way too.
                                                      I could get my tubes out on my own. If you plan take the tubes on your engine out this way, i am having difficulty in seeing how you could use the hydraulic rams in the firebox, or would you push from the front?
                                                      Chris Gunn
                                                    Home Forums Traction engines Topics
