Removing fine burrs
Removing fine burrs
Home Forums Clocks and Scientific Instruments Removing fine burrs
  • #609756
    Steve Crow
      @stevecrow46066
      I've cut a number of small clock wheels.
      I find that when I try to clean up/polish the face of the wheel, whatever method I use, it throws up very fine burrs on the teeth.
      I've tried adhesive lapping film stuck to glass (a method I use for sharpening my leather knives) and fine wet and dry but I still get a tiny burr.
      Has anyone any suggestions for a method for this?
      I keep hearing about Carat paper used by jewellers. Is that a solution?
      George Daniels recommends flattened Water of Ayr stone under running water. Good luck to anybody trying to get that!
      Cheers,
      Steve
      Edited By Steve Crow on 15/08/2022 18:16:37
      Steve Crow
        @stevecrow46066
        #609761
        John Haine
          @johnhaine32865
          Running water or the stone?
          I use a Noga deburrer and a triangular scraper.
          #609766
          Iain Downs
            @iaindowns78295
            I believe (though only through what I've read), that the correct approach is some pegwood and fine grinding paste.
            Iain
            #609767
            Martin Kyte
              @martinkyte99762
              A good modern substitute for Water of Ayr stone, now the mine has closed, is a Shah stone.
              Personally I would not worry over much. The burrs will disappear with first meshing with the pinions. Of course if you are making Daniels grade watches that may be different.
              regards Martin
              #609779
              bernard towers
                @bernardtowers37738
                Try tumbling , there are various mediums for different materials and degrees of aggression
                #609817
                Neil Lickfold
                  @neillickfold44316
                  The very light grey scotchbrite pads, are very good for removing fine burs on all sorts of things, brass, steel, Al, copper etc.
                  #609823
                  Martin Kyte
                    @martinkyte99762
                    What grit are you going down to when you are finishing. The wheels you show are no where near polished. You need to go to at least 5 micron or 1200 grit and then some. Finish of with Autosol.
                    regards Martin
                    #609829
                    Steve Crow
                      @stevecrow46066
                      No, I haven't started on these wheels yet, they are straight from the milling machine.
                      I have tried beyond 1200 but a tiny burr remains on the teeth.
                      #609845
                      Steve Crow
                        @stevecrow46066
                        Posted by Martin Kyte on 15/08/2022 19:14:37:
                        regards Martin
                        Thanks Martin. When I've finished making my depthing tool, I'll give them a good run round with a pinion and see if that does the trick.
