Removing (decorators) paint from Myford Panel
Home Forums Beginners questions Removing (decorators) paint from Myford Panel
  • #461679
    Kevin Murrell
      @kevinmurrell62078
      I have an Myford industrial stand with lovely control panel, but sadly speckled with decorator's dulux some time ago. What would be safe to use to remove these spots?
      Kevin Murrell
        @kevinmurrell62078
        #461686
        David Jupp
          @davidjupp51506
          The edge of an expired credit card, or any similar plastic item with a cut edge. The edges do degrade quickly, but the plastic is gentle on the underlying paint. Use it as a scraper.  Finish off with T-cut if needed.
          I once had to remove hundreds of wind blown spots of paint this way that had landed on the cars in a garage forecourt.
          Edited By David Jupp on 02/04/2020 08:38:46
          #461701
          Dusty
            @dusty
            Some time back I acquired a Myford super 7. This had been owned by a car restorer and was covered in overspray, so much so that I thought the lathe was grey, it was in fact green. I used something called Astonish oven paste. This, though a little aggressive if used too vigorously worked a treat. Finished with some car polish it came up as good as new, well almost. A raid on Swmbo's cleaning cupboard may reveal some, or the Pound shop. I am sure some of the car paint supply shops polishing compound will work just as well.
            #461760
            Dave Halford
              @davehalford22513
              That sounds like an add on ebay a few years ago.
              Refurbished lathe from a 'school'. All bright blue and new looking except they had spray painted everything in one go including lead screw, bed and chuck.
              #461774
              Simon Williams 3
                @simonwilliams3
                Mornin' all
                Methylated spirit will dissolve emulsion paint – albeit slowly.
                HTH Simon
                #461780
                Nigel Bennett
                  @nigelbennett69913
                  I too had a car covered in paint spots – they were painting the car park where I'd left it. And where was this?
                  Paignton.
                  I scraped them off with a finger nail. Took a long time.
