Removing a grub screw
Home Forums Hints And Tips for model engineers Removing a grub screw
Viewing 8 posts - 26 through 33 (of 33 total)
  • #405367
    Jeff Dayman
      @jeffdayman43397
      Mick – LH drills are very handy for repairs on the port shafts and engines of twin screw ships and boats.
      Also very handy for steering gear repairs on cars and trucks in Canada and USA. (LHD)
      Mick Henshall
        @mickhenshall99321
        Does this mean you have to be left handed to use these drills? 🤔
        Mick 🇬🇧
        #405378
        Jeff Dayman
          @jeffdayman43397
          You don't have to be left handed, but it helps! smiley
          Just joking, hope you don't mind my pulling yer leg!
          Seriously, LH drills will often loosen and back out stuck or broken screws without any other brutish attention. When I bought my few, about 5 sizes in total, they only cost about $8.00 total from an industrial tool supplier . They did not cost any more than normal twist drills at that time. I kept them in a plastic container separate from other drills and marked LH. Over the years they have simplified the removal of LOTS of difficult stuck fasteners with no damage to the items they were in, so in my opinion, well worth having, and good value for money too.
          #405384
          Clive Foster
            @clivefoster55965
            Further to what Jeff says in previous post it would probably be sensible to use left handed drills with the drive in, splined shaft, extractors I linked to earlier. If you are lucky the drill will pull the bolt out. If not at least it won't go tighter.
            Maybe I will get a box and some right size LH drills for mine then.
            #405484
            Zane Crowther
              @zanecrowther67531
              I've also recently had a stripped grub screw, I got it loose with the pin punch method.
              I've been told to use a thin wide rubber band, duct tape for extra grip. I've even known people to use a bit of glue to create friction.
              #405490
              Brian G
                @briang
                Bought a pin vice and drill bit set from Aldi a while back. Came with two sets of bits, I thought metric and imperial but no, left and right hand metric. Took me a while to work out why I wasn't making a hole blush
                #405739
                thomas oliver 2
                  @thomasoliver2
                  Here is my method for what it is worth. It is very difficult to drill through the screw dead centre. Drill a hole about 2/3 size right through. Use a parallel diamond burr in a dremel type tool to centralise the hole as near as possible. Then open out the hole with successively larger drills until it is almost out to tapping size. It should then be possible to lever out what remains of the thread fairly easily, say with a bent scriber. Another way is to use a fine tipped diamond burr in a dremel tool to cut a slot across the end then use a screwdriver to turn the screw out.
                  #405961
                  John Reese
                    @johnreese12848
                    Posted by XD 351 on 16/04/2019 12:08:00:
                    Hope like hell it isn’t an unbrako – that usually means using carbide tooling !
                    You can machine Unbrako screws with HSS tools. Just keep the speed low. Yes, it does tend to dull the tool.
