Remove flux from inside of boiler after silversoldering.
Home Forums Model Boats Remove flux from inside of boiler after silversoldering.
  • #51228
    Jens Eirik Skogstad 1
      @jenseirikskogstad1
      Hi folks!
      I has builded the 65 mm dia x 190 mm length boiler with water tube for my model coastal steam boat.
      But the flux from silversoldering are inside the boiler. How can i remove the flux out of boiler before use?
      Will the flux be removed by hot water?
        @jenseirikskogstad1
        #51229
          Keep flushing it out with hot water.
          Or your acid pickle will also remove it.
          Jason
          #51248
            @jenseirikskogstad1
            Thanks, i has removed flux wih hot water..  : )
            #86649
            Steamshy
              @steamshy
              Hi Jens,
              leave your boiler pickling overnight in diluted lemon juice, One lemon squeezed and mixed with 1/2 ltr of water or even less should do the trick, It will remove all the flux
              Andy
            Home Forums Model Boats Topics
