Posted by Bryan Cedar 1 on 07/06/2021 10:55:55:
Having invested a fair sum for a 300ml Reiland oil can, I have found that it leaks badly form the can to screw in top. The top part which is threaded has two large flats where the thread is absent. The leak occurs from these areas even though there is a flat rubber washer that is supposed to seal the joint. A club member that I spoke to has the exact problem. How do Reilang continue to sell oil cans like this?
I have tried different o rings and rubber washers, and the pump continues to leak.
As the can would have to be laid flat in my tool box it is not fit for purpose and will have to be returned.
Apologies for digging this back up but I hope this will help others too.
after having the same issue, I decided to run off a load of leather washers.
the rubber o ring is completely useless once it gets the tiniest drop of oil near it, it just squeezes out of the side of the can.
I have used an excellent quality, veg tanned leather. The inner diameter is a perfect fit for the 200ml pump.
im interested to know if all reilang oil cans utilise the same pump, with just the can increasing in size. If this is the case, these leather washers will fit all models.
If anybody is interested, I’ll happily post them.
£3 per washer £1 postage.
I hope this helps!!
Darren
Edited By Darren Bingham on 22/07/2023 09:00:22
