Regulator, checking operation
Home Forums Locomotives Regulator, checking operation
  • #685732
    Michael Callaghan
      @michaelcallaghan68621
      Hi chaps. I am rebuilding a martin Evans Columbia. I have got to the stage of looking at the regulator. As the regulator is screwed to the front face of the boiler and will be hard to service when the smokebox is in place, I am hoping that someone out there could help me on a few points. The regulator is made up of two spring loaded valves inline with the regulator speed control input arm. My understanding is that best results are obtained if one valve opens a bit later than the other, is this correct. My second question is the best way to check operation before adding smokebox in place. I was thinking of using air, but this would mean that the components would be cold and tolerances off. How would you go about this job. Thanks
      MichaelR
        @michaelr
        You could maybe get enough steam up to test the regulator by using a blow torch in the fire box
        MichaelR
        #689506
        Nigel Graham 2
          @nigelgraham2
          This suggests the design is emulating what was common full-size practice on large locomotives, to use a double-ported regulator. This may have improved sensitivity at partial openings but all my texts explain it relieves the load on the main valve by a small valve putting steam on both sides of it, hence reducing the operating effort needed.
          I don’t know your loco’s design, but on a slide-valve regulator the pilot valve is a small slide working across ports on the back of the main slide. The links make that move before the main slide.
          On a double-beat poppet-valve, the pilot valve is typically a small version working on an aperture through the larger main valve.
          Testing a boiler under steam without the smokebox might not be very easy or effective, and using a blow-lamp is really the only way you can heat it in that condition.
          Really though, the regulator ought work hot or cold; especially one using springs to close the valves. If the materials are nearly similar, and the parts physically small anyway, the differences in expansions will be tiny though may cause problems if your clearances are very tight. I would expect the valve actions to be very slightly loose cold, but the valves should still seal.
          NB: A slide-valve type regulator should never be operated dry as that risks scoring the face. Lubricating it with soapy water should be adequate for a regulator in the dome; a spot of oil for an external regulator.
        Home Forums Locomotives Topics
