Grinding crankshafts is a task that really involves knowing what you are doing, and having the equipment to do it properly..The grain of the wheel and the relative speeds of the work and grinding wheel have be held within fairly close limits.
If the primary surface finish is incorrect, the bearings will fail. Our spec was 16 u inch CLA MAXIMUM,
And secondary surface finish affects bearing life very greatly, if only by controlling the size of the leak path for the oil. The primary function of which is to cool, with lubrication as a secondary purpose. If the bearing temperature is too high the composition of the alloy of the bearing metal changes, and can lead to failure.
(On marine main propulsion engines main bearing temperatures are monitored more closely than oil pressure ).
At 18 CLA the bearings began to mark. At 22 CLA they failed and ruined the Con Rod, Block and Crank.
This provides a copious supply of fag paper thin blued steel, and decorates what is left of the block with sparking white metal!
Get the web radius wrong and a fatigue failure very soon follows..
Broaching of the bearing shells has to be very closely controlled, or that can be another cause for bearing failure.
Main and Con Rod bearings are very highly stressed by inertia loads, which exceed gas loads at high engine speeds, so things HAVE to be right!
Howard..
Crankshaft grinding is like marriage, not an undertaking to entered into lightly!
Howard (This wireless keyboard can't keep up with even my slow typing speeds! )
Edited By Howard Lewis on 22/08/2021 11:04:38
