On
27 August 2024 at 16:42 Fulmen Said:
Glue will be as efficient as chewing gum. 30MPa vs 1000-1500MPa, you do the math…
BUT … Loctite and similar anaerobic retainers do not really work as “Glue” … they are essentially ‘gap fillers’ … So, in the mode to which I referred, 648 should do an admirable job.
If, however, you are decrying their use for glueing the edges of the crack together, then yes I agree.
