Ian, I do hold the club boiler testing gear, including a calibrated gauge,.
John, I did not realise the gauge on the extinguisher was was a much higher range, I should have realised the contents will be at a higher pressure then say 100PSI to be effective. I guess that is why they use coloured sectors rather than indicate the true pressure. Also the construction of the body would point to a higher pressure than is useful to us.
Martin the boiler test includes checking the pressure gauge against the calibrated test gauge.
Chris Gunn
