Recycling aluminium
Recycling aluminium
Home Forums General Questions Recycling aluminium
Viewing 25 posts - 1 through 25 (of 25 total)
  • #85468
    alan knight
      @alanknight67321
      Wondering if its worth melting down aluminium cans and casting them into ingots to be kept for use later. As my company probably throws 3 binliners full away a week. Or would the material produced be of little use?
      alan knight
        @alanknight67321
        #85470
        Speedy Builder5
          @speedybuilder5
          I don't know, but I had the same thoughts about melting down brass taps and fittings etc. Is it worth the gas ?
          #85471
          alan knight
            @alanknight67321
            I was looking at making a 3ph furnace and then do it at work
            #85472
            Michael Cox 1
              @michaelcox1
              Hi Alan,
              I have tried melting aluminium cans. The main problem is that being thin the cans have very high surface area to volume and when melted there is a great deal of dross and a corresponding low recovery of usable aluminium. Recovery is slightly better if you use Lo Salt as a flux.
              Cans are also made from pure aluminium. This is very soft and gummy so it does not machine well. Adding a little copper (circa 2-4%) improves the machinability of the metal.
              Speeder builder5. I think you would get a good recovery of brass from scrap taps and fittings.
              #85474
              alan knight
                @alanknight67321
                Thanks Michael, we have about 30kg of old brass hinges really heavy unlacquerd type, I could get an endless supply of brass at the prevailing scrap rate so would that be a more useful path?
                #85476
                Michael Cox 1
                  @michaelcox1
                  I find scrap aluminium everywhere. Possible sources are old carpet joining strips, old aluminium furniture, old shower rails, old car wheels, old hard drives etc.
                  The advantages of aluminium are that it is plentiful, it melts at a relatively low temperature (circa 650 degrees C) and it can be melted in easy to find stainless steel containers. Furnace construction is not critical because the temperatures are fairly low.
                  Once you move to melting brass then the melting temperatures are much higher (circa 1000 degrees C). The furnace construction is more critical, special clay graphite crucibles (expensive) need to be used and zinc fume (toxic) is troublesome. The potential dangers of the process are large.
                  I would advise try aluminium melting and casting first and then move to brass once you have some experience.
                  #85482
                  Keith Wardill 1
                    @keithwardill1
                    This thread has some information – http://www.model-engineer.co.uk/forums/postings.asp?th=45889
                    I have been making my own ally castings for years by various methods. Tins are a total waste of time – they are coated with some kind of plastic which burns off and leaves vast amounts of dross on the metal. I usually go down to the scrapyard and buy an old cylinder head if I have large bits to cast – that way the metal is consistant, and it doesn't matter what condition it is in, so you should only pay scrap prices, not spare parts prices. (I know – scrap price is high enough cheeky). As Michael Cox says, it is not too difficult to find assorted aluminium scrap if you look around – never had much problem.
                    I have used the trick of dropping in a small piece of copper – the resulting alloy is quite pleasant to machine. Biggest problem I have had is voids in the finished piece – using flux when melting will stop this.
                    Also a safety issue – in the early days I tried using stainless steel cans for smelting – these will rapidly erode away, and dump hot ally everywhere ('Erode' is the only way I can describe it – it can't be hot enough to melt the stainless – maybe someone with some metallurgy background can explain). The genuine crucibles are expensive (and hard to find where I live).
                    #85487
                    wheeltapper
                      @wheeltapper
                      Michael, I'd be wary of old car wheels, they could be magnesium, hence the term 'mag wheels'
                      should burn well tho.
                      Roy
                      #85504
                      MadMike
                        @madmike
                        Be careful if you are melting aluminium, as the alloys are different for the many uses to which it is put. Best to melt extrusion or plate if you can.
                        As for car wheels there are few magnesium wheels in general circulation. The majority, possibly 99%, will be aluminium. Mixing the alloys will give you a chunk of aluminium of more than dubious quality. However that may not be an issue to some people.
                        In particular beware of drinks cans. Carefully check the can walls. these are often plastic these days rather than aluminium. The end caps are still generally aluminium.
                        HTH rather than confuses.
                        #85509
                        alan knight
                          @alanknight67321
                          So your saying stick to a single alloy for a job, eg mabey heads for casting cylinder heads and crank cases or wheels for more general use.
                          #85512
                          Jon
                            @jon
                            Been thinking along the lines of something that dont take up much space. Whether it chops it or compresses together not bothered.
                            Just next weeks alum scrap value alone i could weigh in £72 est which could take 8 weeks to get rid of in wheely bin collections.
                            #85527
                            Terryd
                              @terryd72465
                              Hi,
                              This guy does a lot of home casting for his engines and his self made videos are well worth watching. This is what he has to say on recycling aluminium for casting (including a simple test for magnesium in alloys):
                              Best regards
                              Terry
                              #85532
                              Ian S C
                                @iansc
                                I think the way it should be smelted ,is to start the melt with other scrap, then put the clean dry, and flattened aluminium cans in a paper bag, and plunge it into the molten aluminium.
                                If you want some cans, I'v got about 50 kg of flattened cans behind my workshop.
                                Ian S C
                                Edited By Ian S C on 23/02/2012 09:18:53
                                Edited By Ian S C on 23/02/2012 09:19:57
                                #85552
                                peter walton 1
                                  @peterwalton1
                                  I think the video is showing that the larger the surface area of the scrap Ally the less you will get in the actual melt due to the surface oxidising.
                                  This is why ally turning have so little scrap value, to high an oxidxe content.
                                  peter
                                  #85554
                                  Dithering
                                    @dithering
                                    Wotsit: The reason for the erosion of your stainless steel containers is that iron actually dissolves in molten aluminium so any iron-based metal crucible will have a short life. On the other hand, Poundland sell stainless steel pots very cheap – I think I bought 4 for £1.
                                    SpeedyBuilder5: Year before last, at the Midland Model Engineering Exhibition, there was a guy melting brass to cast house number plates (I can think of more useful things to cast!). He was largely using old, chromed taps but it took a long time and a lot of gas to melt them. Partly, this was because he was out in the open and it was quite cold but I should think that he wouls have to be in the open because there were a lot of fumes and the flames were roaring about 5 feet high.
                                    Michael Cox 1: I have a collection of old hard drive chassis which I intend to melt down. I'm not sure, though, that they are aluminium. Possibly, they are zinc. Anyone know a test to distinguish between the two.
                                    Brian Thompson.
                                    #85556
                                    Gordon W
                                      @gordonw
                                      What are ready-meal food trays made from? I tried melting a couple (just with a torch) as an experiment, and they just turned to dust. Could it be some coating? A storey on the radio I heard:- Some Aussie is reconned to be the biggest lager drinker/ most for longest time, it was calculated that if he'd kept all the cans the scrap price now would have paid for his beer over all the years.
                                      #85557
                                      Michael Cox 1
                                        @michaelcox1
                                        The appearance of some zinc alloys is very similar to aluminium alloys. All the hard drives I have had have been aluminium. There are two ways of distinguishing aluminium and zinc.
                                        The first is based on the density. Zinc is much heavier than aluminium for the same sized piece (zinc has a density of 7.1 g/ml and aluminium 2.7g/ml) Density can be easily determined by weighing dry and then immersed in water.
                                        The second test is based on the fact that zinc will dissolve in dilute acids such as vinegar liberating hydrogen whereas aluminium will not readily dissolve. So just sprinkle a little vinegar on the metal. If it reacts and froths it is probably zinc. Note this test also distinguishes aluminium and magnesium alloys (see the video link in Terryd's response).
                                        In summary, if the metal is light and reacts with vinegar then it is probably magnesium based, if it is heavy and reacts with vinegar then it is probably zinc based, if it is unreactive to vinegar then it is probably aluminium based.
                                        #85558
                                        Swarf, Mostly!
                                          @swarfmostly
                                          Brian:
                                          If you have a spring balance and a bucket of water, you can determine the specific gravity of the casting. This is an up-to-date version of Archimedes 'eureka' method.
                                          Weigh the casting hanging in air and then weigh it again immersed in water. It will lose the weight of its own volume of water. The specific gravity is equal to the dry weight divided by the difference between the dry & wet weights.
                                          Suppose it weighs 10 kg in air and 8.5 kg immersed in water, then the specific gravity is equal to 10/(10-8.5) ie 10/(1.5) = 6.7 (This example doesn't apply to a real metal – I've just used easy numbers to show the method of calculation.)
                                          Then look up the SG on the internet or in some Tables of Physical Properties. This method will distinguish easily between aluminium and the zinc-based die-casting alloy (aka 'Mazak&#39. I think pure zinc castings wouldn't often be encountered, Mazak would be more likely.
                                          If you don't have a spring balance, you can use a rod or beam and a counterweight, with bits of string to suspend the beam itself and the casting and counterweight from the beam. You measure the distances from the beam pivot to the casting's string at the balance points dry and in water (keep the counterweight in the same position and move the casting to balance in each case. It's a bit more difficult to explain in a forum like this but by manipulating the two distances, you can calculate the SG.
                                          I hope this helps.
                                          Best regards,
                                          Swarf, Mostly.
                                          #85559
                                          Swarf, Mostly!
                                            @swarfmostly
                                            Mike,
                                            You beat me to it!!!
                                            Best regards,
                                            Swarf, Mostly.
                                            #85566
                                            Keith Wardill 1
                                              @keithwardill1
                                              Dithering,
                                              Thanks for the input – I mentioned about this happening because there was a suggestion earlier to use stainless steel cans for smelting, – I wanted to point out that this is a dangerous practise. When I first started, I thought stainless cans would be just the thing. I did not know at the time, and would have found it hard to believe that ally at 650 degrees would 'dissolve' or otherwise penettrate stainless steel -The first one lasted for about three smelts, then dumped ally – fortunately inside the furnace, so no harm done. The second one I tried failed at the second attempt, and dumped ally around my feet – I was very glad I had boots on – it also boils the moisture in concrete, which spits violently. The same phenomenon occurs with the chunk of copper suggested in this thread to make the metal easier to work – copper melts at a much higher temperature than ally (my forge certainly won't melt it), yet there is no trace of the lump of copper in the resulting ingots – it dissolves (or otherwise merges) into the ally.
                                              I mention this again, because someone in this thread suggested stainless steel cans for smelting, and the thread seems to have missed that point completely. I use a thick homemade iron can, with a coating of clay inside. Even for 4 cans for a pound, its not worth the risk with stainless.
                                              I have used many old harddrive castings for smelting – so far all of them have been aluminium.
                                              Has anyone reading this forum actually used rubbish metal like drinks cans or picnic trays to produce useful castings with any sort of bulk? – I always had far too much dross, as many people also say in this thread (and on many other threads, over and over again) – IMO, it simply is not worth the time to collect the damn things, then melt them down, then decide what to do with the resulting crap, 'cos it sure isn't useful metal. There is a thread somewhere in this forum (I think) which discussed this long ago, with some interesting details on metal thickness and coatings – the opinion then was forget it.l
                                              #85577
                                              Michael Cox 1
                                                @michaelcox1
                                                I have been using stainless steel containers as crucibles for a long time without any problems due to perforation. I always heat a new container in the furnace for several minutes to build up a oxide layer before using it to melt metal. I believe this oxide layer protects the metal from dissolving in the aluminium. I am careful not to scratch the sides of the vessel when stirring the molten aluminium.
                                                At the end of each casting session I clean the crucible using hot caustic soda solution. This dissolves any aluminium stuck to the crucible. Once clean the crucible is inspected for any damage to the oxide layer. If there is damage to the oxide coating then I would discard the crucible.
                                                Some of my stainless steel crucibles have been used for 30 melting sessions.
                                                Clay/graphite crucibles also have a finite lifetime and if they fail in use this is most likely to be due to cracking. I think that this type of failure is potentially more dangerous than a small pinhole developing in a stainless steel crucible.
                                                #85595
                                                Sub Mandrel
                                                  @submandrel
                                                  Mike Cox is hiding his light under a bushel – it's worth finding his artilces in MEW near the end of last year on aluminium smelting. they certainly make me want to have a go at it.
                                                  Ian S C
                                                    @iansc
                                                    Went and had a look at my copy of "The Backyard Foundry" by B terry Aspin, (Chuck), a book well worth having, thought the bit about cans in paper bags was in there, but no, must have been in ME. The idea is that you get the cans into the melt without them being exposed to too much air, or they will oxidise almost instantly, like the pie dish mentioned a few posts ago. Ian S C
                                                    #85629
                                                    Keith Wardill 1
                                                      @keithwardill1
                                                      Michael,
                                                      I  also have been making castings for many years, and I just have to disagree with you, if only for safeties sake – Many sites dealing with aluminium mention the risk of using steel containers – the failures I have had were not  'pinholes' – large areas of the steel disappeared with no warning – cleaning/heating them does no good. On the other hand, crucibles can usually be seen to be cracking, and therefor avoided. As I noted, I use a thick steel can with a clay liner – so far that has survived for about three years – no cracks, no failures, no risks.
                                                       Of course, you are free to take the risk – but at least others should be aware of the risk of getting molten aluminium at 700 degrees on their feet.
                                                      This thread has covered most of this stuff before, including comments from current contributors.
                                                      Edited By wotsit on 24/02/2012 10:33:31
