Are you talking about the cylinder side of the head with it's double depth recesses? and your "washer" will actually have 3 holes for valve and spark plug?
If so it's worth giving it a go, the JBW should take the heat and the screw which could be smaller will keep it in place if the adhesive does fail.
From Brian's build thread
