I would go for 316, it may be more difficult to machine, but I often use it on a Myford so it’s not that bad. If drilling use a sharp drill AND cutting fluid. Good luck. Noel.
Me too. The issue isn’t how easy or not the steel is to machine, it’s avoiding corrosion. Not because corrosion shortens the life of the component, but because some of it ends up in the coffee, perhaps enough to damage the health of the drinker.
Stainless steel contains a lot of Chromium, and the salts of this, i.e, ‘corrosion’ aren’t nice. They cause ulcers and many are carcinogens. The metal is safe when locked inside the alloy, but not if a chemical reaction with hot coffee releases it. Also, lots of Nickel in stainless. Also a health risk, but not so bad.
Looking up 304, Wikipedia says ‘It is subject to pitting and crevice corrosion in warm chloride environments and to stress corrosion cracking above about 60 °C’ My bold. 304 isn’t suitable for hot coffee!
316 is a much better choice for this application: higher corrosion resistance, and not temperature sensitive. Molybdenum locks the Chromium and Nickel more firmly in place, the disadvantage of 316 being increased cost and reduced machinability.
