Recommended collet chuck
Home Forums Beginners questions Recommended collet chuck
  • #191685
    Colin LLoyd
      @colinlloyd53450
      My S/H Chester Mini/Multi Lathe/Mill machine came with just MT1 taper drill chucks – which I have been using for milling. Now I find that, for various reasons, these are not really appropriate for milling and I need to get a Collet Chuck. My web searches has thrown up that ER Collet chucks are the most widely used. But these come in various sizes. Bearing in mind the limited milling capacity of both the machine and my use – i.e. I currently use end mills from 1mm to 5mm – which ER Collet should I go for ER-8, ER-11 or ER-16 to have the best compromise solution. Or am I just going down the wrong path entirely.
      Colin LLoyd
        @colinlloyd53450
        #191690
          As you probably also have quite limited space between the mill spindle and the work you may be better off using MT1 collets that fit directly into teh taper and will save you a couple of inches.
          These are only suitable for nominal sizes eg 3mm, 4mm, 5mm (or 1/8" 5/32", 3/16" ) not a problem with milling cutter shanks but you would have to switch to a drill chuck for intermediate sizes when drilling etc.
          The ERs will allow you to grip anything within each collets range so will save some time in changing between collet holder and drill chuck but at the cost of room not just the length mentioned above but also the dia of the closing nut can get in te way at times when using small cutters. I'm not sure that there are may MT1 collet holders about in te smaller sizes anyway.
          #191692
          Colin LLoyd
            @colinlloyd53450
            Hi Jason, thanks for quick reply – Am I right in assuming that the MT1 collet size (3mm, 4mm, 5mm) refers to the shank diameter and not directly to the end mill diameter. Most of my small end mills are on much larger shanks (probably 4mm or 5mm).
            #191710
            Thor 🇳🇴
              @thor
              Hi Colin,
              You are right, many end mills/slot drills come with a limited number of shank diameters – 6mm, 10mm and 12mm for instance. The diameter of the cutter part can be 6mm, 5mm, 4mm etc. I do have some end mills where cutter diameter and shank diameter are the same though.
              Thor
              #191716
                Yes as Thor says the collet size is the actual dia it will grip, all my cutters 6mm and below have a 6mm shank, likewise the imperial ones between 1/16" and 1/4" all have a 1/4" shank so really only need one 6mm and one 1/4" collet to hold them all.
                #191959
                Ajohnw
                  @ajohnw51620
                  I think Jason hit the nose on the head when he suggested morse collets. I have a dore westbury. It's morse 2 in a hefty spindle and that type of collet is the best option for a lot of work. I bought suitable metric and imperial collets because I like to buy bargains when they crop up.
                  I think you will find that standard shank diameters in your sizes are 3,4,5,6 and 8mm diameter. The actual cutting diameters at these sizes will vary. You will find that it's possible for instance to get 3mm cutters with a 6mm shank. The other smaller sizes of shank are more likely to be found on solid carbide cutters. You could get a better idea of the variations in this area by browsing ArcEuro's pages. They for instance only sell cutters with 6,10 and 12mm dia shanks.
                  ER collet holders sound very attractive but are just as much pain to change as a morse collet when a change is needed. I am not aware of any 1 morse versions anyway. I do use an ER16 holder at times because of the size of the quill on my miller – they give more reach from the quill and also give me a better view of what is going on. The parallel shank ones are often used on "big" milling machines for the same reasons. My DW isn't big but is based on a Myford lathe spindle nose.
                  Bob Brown 1
                    @bobbrown1
                    I have a Dore Westbury with an ER 32 chuck screwed on to the Myford nose, ER 11, ER16, ER20 and ER 25 MT1 collet chucks are available and will give a larger range of collets e.g. ER11 0.5 to 7mm ER25 1 to 16mm with the other sizes sitting in between. As individual ER collets cover a size range clamping say 6mm to 7mm so will also accept imperial sizes.
                    Bob
                    #191965
                    Ajohnw
                      @ajohnw51620
                      Not relating to this thread but I am happy with what I have at the moment. I don't mill that often and work is small so I cope. I will probably add an ER25 holder at some point when and if I need to. I also intend to make an adapter for screw on face cutters using the myford nose. I have a box of face cutters but so far haven't needed to use them.
                        Bob have you got a link to the MT1 chucks, a quick look around the usual suspects did not show any.
                        J
                        #191967
                        Bob Brown 1
                          @bobbrown1
                          JasonB,
                          Here you go **LINK** amongst others I have used them in the past without any problems other than you have to factor in customs and excise plus the delay in shipping.
                          Purchased a full set of ER 40 collets off them took less than 2 weeks to arrive and missed the customs bit.
                          Bob
                          #191968
                          Saxalby
                            @saxalby
                            CTC Tools do ER11,ER16,ER20 and ER25 with a MT1 Shank.
                            http://www.ctctools.biz/er-collet-chucks/?sort=featured&page=1
                            Oops beaten to it by BOB
                            Edited By Saxalby on 01/06/2015 11:53:09
                            #191970
                              Thanks Bob & Sax
                              Edited By JasonB on 01/06/2015 12:07:06
                              #191971
                              Colin LLoyd
                                @colinlloyd53450
                                Now here's a very naive question – but one I can't seem to find the answer to. Why are there so many different taper designs, and why even within one taper design (e.g. Morse Tapers) are there so many varieties? I understand the difference between binding tapers and drawbar tapers but this still doesn't explain all the other variations.
                                #191973
                                Bob Brown 1
                                  @bobbrown1
                                  a bit of light reading, **LINK**
                                  #191975
                                  Colin LLoyd
                                    @colinlloyd53450
                                    Thanks Bob – I read the wikipedia entry as well – but it failed to explain why there were Brown & Sharpe, Jacobs, Jarno, Morse, B Tapers, NMTB tapers, HSK tapers etc. Providing the taper is big enough and man enough to cope with the different rotational forces encountered as the material size increases – why so many variations. I appreciate quick release tapers (NMTB) or coping with high centrifugal forces (HSK) but beyond that – why so many. It just strikes me as a similar situation to current USB plugs – where everybody decides to create their own form despite the fact that the underlying reason and format is common and intended to do the same job. Fortunately, USB plugs/sockets appear to be converging to a common design. With the longevity of lathes and milling machines, I doubt that will happen – although it seems that recent machines appear to be gravitating towards Morse tapers – at least in the hobby/model area of machinery.
                                    #191981
                                    Ajohnw
                                      @ajohnw51620
                                      laughYou missed Schaublin Colin – sort of morse like. They chose to do that. Some of the various types will have been made for the same reason.
                                      I'm not going to look at that lot, just general.
                                      There are basically only 2 types – locking tapers such as morse and ones which don't or shouldn't. A rule that is sometimes used for not locking under any circumstances is a 30 degree half angle. With oil I would wonder about that in terms of pulling it out.
                                      Morse on cutting tools should really use a tang on the end to ensure it doesn't slip hence it's wide use on drills. A draw bar can also help.
                                      The various milling chucks are in one way or the other down to the the size of the machine particularly the size of it's spindle and the available motor power. The larger miller specific ones will generally lock into the spindle so the taper is more for accurate alignment. This can even extend to the collets used in them such as with clarkson auto lock. The cutters have a thread on the end so any slippage screws them in further until they can't go any further. The collet grip alone seems to be more popular these days but I don't know many people who have 5HP millers, not much idea how powerful they can get either.
                                      I'm glad you realise that cutting torque matters. Just because some on sells a morse 1 ER collet holder doesn't mean it's a sensible thing to use. People have been known to bend even MT3 arbours on millers. Any morse fitting collet holder extends significantly out of the spindle – morse collets don't so less leverage is applied. You have a fairly light weight machine so personally I would be inclined to bear that in mind.
                                      Edited By John W1 on 01/06/2015 13:35:24
                                      #191984
                                      Keith Long
                                        @keithlong89920
                                        Colin the quick answer to "why so many" is probably histrory. Back when machine tools were being invented and developed there was very little if any likelyhood of a milling cutter made in America being used in a milling machine made and used in the UK. So while both America and the UK thought that a standardised taper would be a good idea, in their own countries, there was no need for them to have the same taper as each other – even though the mechanics of the situation would dictate that they would inevitably be very similar. Now apply that same logic across the rest of the world and you can see where so many different but very similar National and Manufactures Association standards come from. It is probably only from the late Victorian era that international trade in machine tools got going and then only on "high-end" machines which would be almost one-offs, so the machine builder could put whatever taper the customer demanded on the machine. Now-a-days markets are global and machines and tooling are often built and produced in different parts of the world. New machines will have the more widely accepted international standards but there a still a heck of a lot of older machines around that need tooling to the old standards. USB plugs and computers have come from a different direction in that global markets were already well established and standardisation was an obvious thing to do.
                                        A good example of how multiple standards come about is the electric vehicle market. The large car makers all develop their own take on the vehicles and systems – partricularly the charger connection – result was that you couldn't charge say a Ford from a Peugeot charger even though the voltage etc was right – the plug didn't fit! I pointed this out about 20 years ago at a conference and suggested that since petrol cars could all go to the same pump for a refill as the nozzles were all the same size wouldn't it be a good idea to use the same logic with the electric cars and standarise on "refill" connectors – didn't get a good reception for some reason! I note that mobile phones are now or are to be being fitted with a standard charging connector – about time!
                                        Edited By Keith Long on 01/06/2015 13:49:56
                                        #191985
                                        Bob Brown 1
                                          @bobbrown1
                                          Posted by John W1 on 01/06/2015 13:33:58:
                                          I think you would be hard pressed to bend a MT3 ER collet without some kind of mishap/mistake on the part of the operator or any other tool holder if it comes to that, so I think the comments are unreasonable. I have been using ER collets for several years both on the milling machines and the lathe, never bent one, broken a few tools but the collets have been fine and have not had a tool move in them.
                                          Small machines are not going to be capable of large cuts and large cutters are probably not advisable, one has to work within the constrains of the machine.
                                          Bob
                                          #191992
                                          Ajohnw
                                            @ajohnw51620
                                            Posted by Bob Brown 1 on 01/06/2015 14:00:26:
                                            Bob
                                            I sold a sensitive DTI to some one after finding I had 2 some how or the other who had done just what I said and wanted to straighten it. I have also seen bent 3 morse milling collet holders in used machine tool sellers stock. Much depends on the power of the miller and the size of the cut and cutter it will take but by all means use what ever you see fit to use. Really there is no point fitting a collet holder that can take bigger cutters than the machine can usefully use.  A rough metric for that is a depth equal to the diameter with some care. Light cuts with face and fly cutters are a different matter.
                                            Edited By John W1 on 01/06/2015 15:15:04
                                            #192018
                                            Trevor Drabble 1
                                              @trevordrabble1
                                              Colin, As an alternative , may I suggest Dave Chambers at D&J Workholding on sales@djworkholding.co.uk and 01993 200119. They supply a large range of styles of quality tooling arbours and collets , incl MT1 in different precision grades. NOT CHEAP, but good . No connection with company other than as a satisfied customer. Hope this helps.
                                              Trevor.
                                              #192087
                                              Colin LLoyd
                                                @colinlloyd53450
                                                Have just learnt a salutary lesson – that hasn't really been a problem during my previous extensive working with wood. Measured the milling end-mills etc with my vernier calipers. OK shank = either 6.3mm or 3.1mm. Just need to get 6mm and 3mm collets. WRONG. Collets arrived – tools don't fit. Measure again – yep 6.3mm and 3.1mm shanks. WAIT 1/4" is 6.35mm and 1/8" = 3.175mm. So all my endmills etc are imperial not metric.
                                                Note to self: need to be more precise in metalwork.
                                                #192089
                                                Ed Duffner
                                                  @edduffner79357
                                                  Hi Colin,
                                                  You'll probably find the 1/8"(3.175mm) shank tools will go into a 3mm collet if you back off the collet nut slightly. I've found that ER collets allow a certain degree of over-size cutters to be inserted as well as the clamping range of say 3mm down to 2mm.
                                                  Ed.
                                                  #192123
                                                  Colin LLoyd
                                                    @colinlloyd53450
                                                    Hi Ed, Yes – I tried that and the tool goes into the collet but then the splayed collet doesn't go far enough up into the taper for the drawbar to connect with the collet. But never mind – I've ordered some Imperial collets – not expensive and widens my range of possible tools.
