UK (and USA ) produced machines, up to the 70s, are most likely to be Imperial (Obviously you would expect machines produced on the continent will be Metric )
Modern, and new machines will almost certainly be Metric.
Don't dismiss an older machine. It may be lack some of the features present on a modern machine, but excellent work can be produced on machines that are a lot older than you or I,
There may be fewer speeds available, and will mean changing belts rather than just pressing a button. Feed rates, or thread pitches may be fewer and less easily changed.
The asking price will reflect this.
The problems likely to be found with a secondhand machine are:
Wear (Especially if it has been earning its keep in an industrial environment. Myford ML7s have been used in Toolrooms, as well as a hobby machine. ).
Ex School or College machines will be less worn, but more likely to show damage from Saddles having been run into the chuck.
The machine may have been modified away from original spec. This may be good, or a disadvantage, depending on your viewpoint and needs.
Accessories, supplied from new, such as changewheels, or or only one set of jaws for 3 jaw chuck may be there, or damaged. And may be difficult to replace, in some cases. But can be made.
The toolkit which usually came with a new machine may be missing or incomplete.
Chuck backplates may not be available "off the shelf" for some machines, and so would have to made.
The Chester Craftsman is still available from new.
If having power feeds in both planes is important, the Sieg SC4 provides this facility, in a smaller machine than the Craftsman.. .
Buying new provide should provide support should a problem arise, and accessories should be available.Some importers will sell you a fairly basic machine, at a lower price, and supply accessories which you can buy as you feel the need. Some off a "Starter kit" as an extra. Other Importers sell a complete package.
(My lathe came complete with 3 and 4 jaw chucks, Faceplate, and Steadies. )
Buying secondhand, reduces the price, although 7 Series Myfords tend to more costly than Boxfords or Raglans, but spares are more readily available, either used or, in some cases, new..
Buyers were often able to specify certain features on a new machine ( One 7 Series Myford might have a Norton gearbox, while another might not, but have power cross feed. Another might have have both!
It pays to check the machine very carefully )
What you want to make, location, space available, and your budget, will all have a bearing on what you buy.
You can carry a Myford ML10 upstairs, a 300 Kg Craftsman or its lookalikes will be MUCH more difficult.
And do make provision in the budget for tooling and measuring equipment.
As your horizons expand, you may want to move to a larger or more versatile machine. It might be worth allowing for this from the outset..
Hope that all this rambling is of some help
Edited By Howard Lewis on 30/04/2022 08:07:12
