Rear Toolpost Parting Off on C3 Mini Lathe?
Home Forums Workshop Techniques Rear Toolpost Parting Off on C3 Mini Lathe?
Viewing 25 posts - 1 through 25 (of 26 total)
  • #50088
    marcusj
      @marcusj
         Has anybody any suggestions for rear toolpost parting off on a C3 Mini Lathe?
      marcusj
        @marcusj
        #50091
        Michael Cox 1
          @michaelcox1
          Hi Marcus, the problem with fitting a rear toolpost to the standard cross-slide is that you end up with very little space between the front and rear toolpost and this then severely limits the workpiece diameter.
          One way round this is to use the front toolpost but with the parting tool upside down and running the lathe spindle in reverse. This then creates the same parting conditions on the front toolpost  as would occur if a rear toolpost were fitted.
          The second solution is to remake the cross slide so that it is longer to provide more room for the rear toolpost. I have done this to my Sieg lathe. Parting off becomes very easy with a rear toolpost..
          #50094
          keithmart
            @keithmart
            Hi
            You have a reverse motor on this lathe I believe, in whch case you only have to mount your parting tool upside down, and on centre to achieve the same effect.
            Keith
            Leeds UK
            #50128
            marcusj
              @marcusj
              Thanks for the quick replies.  Looks like I’ll be making some special toolholder, probably to completely replace my A2Z CNC quickchange as a special, solid, rigid, parting-off toolholder / post combo.
              #50322
              marcusj
                @marcusj
                OK, have tried turning my part-off tool upside down and mounting it (rather poorly because I run out of vertical adjustment) in the A2Z QCTP.  Hurrah – I can now part off aluminium alloy (55mm OD).  Seems to work with less complaint if I add some drops of cutting fluid (Tap Magic) every now and then.  Steel would probably still be ‘one step too far’ with the current set-up (still running ball bearings on the headstock, not taper rollers).  At the very least I would want a much more solid tool holder and probably need to make, fit and use a carriage lock.
                Edited By marcusj on 01/04/2010 11:11:05
                #50329
                mgj
                  @mgj
                  With respect, but parting off without coolant seems a little strange to me.
                  Its asking for a jam up. (and a poor finish.)
                  If you have a problem, I suggest running up the tailstock and giving support that way.
                  In many ways I sympathise, because I have been through the pains of front and rear toolposts and  endless jams up, in both front and rear set ups.
                  Not any longer (and note that most lathes don’t have a rear toolpost facility.)
                  If Imight suggest it, ensure you have a tool with relatively little back rake so there is no component to draw the tool into the work.
                  Ensure the tool is genuinely square to the job, use a lot of coolant and feed firmly and positively to maintain a resistance and enure that all backlash is taken up.
                  Nowadays I use a carbide tip in either  Sandvik , Kit Q Cut or Glanze blades, with coated Sandvik or Zenit tips. However, but I still use ground blades for particular purposes – usually handed parting to ensure the right bit drops off .
                  I have no intention of using a rear toolpost again for all the hassle and confinement it causes, and I haven’t had a jam up for years.
                  #50331
                  Sub Mandrel
                    @submandrel
                    Hi Marcus
                    Hope it doesn’t feel like I’m following you around…
                    If roller bearings don’t solve your parting troubles – parting is such sweet sorrow
                    Try this – a t-slotted table from continuous cast meehanite (from College Engineering)  and simple toolpost from the same (fixed by two 6mm screws into a double-hole t-nut). A competitor for Tubal Cain’s ‘Gibraltar’ toolpost.
                    Gordon W
                      @gordonw
                      I’ve just come in from w/shop, making an upside down parting tool for my slightly bigger than a mini lathe. I’ve read lots on why rear parting or upside down in reverse works so well, and I’m idly thinking why don’t we do all turning this way? Surely the mechanics are the same? Please tell me where I’m wrong.
                      #50344
                      mgj
                        @mgj
                        Because its completely unecessary and puts the forces into the x-slide the wrong way.
                        ie it lifts the x slide, and is therefore less rigid than using it in compression down onto the the bed.
                        And it doesn’t work so much better if one has ones act together.
                        I should have mentioned above, along with having the right tool geometry, you need the tool set just a tiny bit below centre height at the front – that means that if you are a bit enthusiastic, it creates a component which thins the cut and unloads the tool. ie its excatly the same geometry as being a touch high at the rear. What you mustn’t do is be above centre at front (or below centre at rear) because then the tendency is for the depth of cut to increase with load, and the result is a jam up, front or rear.
                        Edited By mgj on 02/04/2010 11:03:10
                        Edited By mgj on 02/04/2010 11:03:31
                        #50346
                        michael bird
                          @michaelbird72946
                          hi mgj
                          If I am using a KIT-Q-Cut mounted upside down in the front tool post, and running the lathe in reverse, should the tool be above or below the centre line.
                          Bob
                          #50349
                          Circlip
                            @circlip
                              In ALL cases, ON the c/l
                              Regards  Ian
                            #50350
                            chris stephens
                              @chrisstephens63393
                              Hi Guys,
                              No one has yet mentioned the “sprung” parting tool holder of the “swan neck” variety.
                              Somewhere I have a catalogue from the 40-50’s that show the style, if and when I find it again, I shall post a scan for your amusement. The style was recently revived by  Cherry Hill’s hubby and was shown on the SMEE stand at (IIRC) Harrogate a few years ago. Those who have used it claim smooth and trouble free parting.
                              chriStephens
                              #50357
                              mgj
                                @mgj
                                Not so Circlip (we are talking of a few thou).
                                As I said, if you are below centre at the front with any parting tool then the tendency is to push the tool (downwards)towards a thinner cut, so you have a “safer” set up. In other words it won’t drag the tool in or increase the cut so it wont jam. (Unless you have excessive rake which was my old trick – thankyou CS for the steer)
                                I set up on the C/l and then tweak the QCTH a tiny bit. Thats all it needs.
                                Michael – please think about it and the answer is obvious. If you are running forwards and you want to be below, then in reverse….Thats not being hard – its trying to get people to see where forces and thrusts are taking them.
                                But,  what are you doing with any parting tool running in reverse at the front. You are lifting the cross slide off its base and into free space, and de-rigidifying everything.
                                I’m delighted you have a Kit Q Cut- so do I. Magic. Ploughs though everything at high speed, and never jams, but in the bowels of Christ, never once have I seen any cause to cut in reverse at the front with ANY tool (except when matching internal and external tapers which is hardly normal). For Heavens sake, put the forces into the bed the way the designer intended unless you have a very specific reason for not doing so.
                                Which is a very good reason for NOT cutting at the back. And if I can do it on a 30 year old Myford still on its original front bearing, so can anyone else. All it takes is a bit of thought about the geometry, (and rejecting the conventional thought about rear tool posts, which clearly is wrong, an oversimplification in engineering terms, and inconsistent in result) getting the rake right, and using the machine in the direction where it is most rigid.
                                Speaking as someone who could generate several jams in a single parting attempt in 1″ bar.
                                #50380
                                michael bird
                                  @michaelbird72946
                                  Hello mgj
                                  the reason I am considering parting off using the front tool post with the lathe in reverse is because I do not have a rear tool post and my cross slide does not have T slots.
                                  Cheers
                                  Bob.
                                  #50381
                                  mgj
                                    @mgj
                                    Fine Michael – so why lift the x slide off the bed rather than drive it onto the bed as the good lord and the designer intended. If you look at your geometry and forces/vectors you will see that if you have the tool set incorrectly you will provoke a jam just the same.
                                    What is the benefit? Most of the rest of the world has lathes that also have no facility for a rear toolpost, and they can part off OK at the front, so what provokes this?
                                    My approach when I had all these horrendous parting difficulties was to say that if “they” can and I cannot, then I am doing something wrong, or I am setting up conditions which cause a jam. That being so, one can analyse and rectify. Which mercifully I have done.
                                    To start running in reverse seems a little quaint?
                                    #50382
                                    michael bird
                                      @michaelbird72946
                                      mgj
                                      excuse me for being very much a beginner, but if one is parting with a rear tool post with the lathe running forward, is there not the same lifting force on the cross slide as would be the case when parting from the front with the lathe running in reverse.
                                      It would seem that many posts on this site advocate that parting from the rear is the answer to most parting problems, ease of chip clearing etc.  So it would seem to me that without a rear post, the way to go is with a front post and the lathe in reverse.  Thanks for your time
                                      Bob
                                      #50383
                                      David Clark 13
                                        @davidclark13
                                        Hi There
                                        Psrting off upside down from the front is OK if you don’rt have a threaded mandrel like a Myford.
                                        If you do, the chuck would probably unscrew.
                                        regards David
                                        #50385
                                        mgj
                                          @mgj
                                          Michael – you are quite right.
                                          But my point is that 99% of the world doesn’t part off at the rear, they  part off at the front – and very successfully.
                                          Yes many people do suggest going to the rear as it were. Good luck to them, but it isn’t the answer, because you can get jam ups at the back with this wonder geometry they all use. (I know from personal and very painful experience)
                                          The answer is not to try to emulate this miracle (PITA actually because you end up all cramped up on a small cross slide), but to get it right at the front. If, as most people do (myself included at one stage) go for the steep back rake recomended by some authors (often from the days when lathes had much less power available) or use no coolant, or don’t take care to get tools square and at the right height so that if they dig in they tend to dig deeper rather than shallower, then you are getting down on your knees and begging for trouble, and one shouldn’t be surprised if it arrives in full measure.
                                          (for instance – no coolant? OK apply a 90thou cut (2mm) you are doing a fair bit of work. The tool heats up – expands – the work heats up locally – expands. No wonder it jams, and we haven’t talked about rake angles pulling the tool into the work unrestrained because of backlash in the feedcrew nut (front or back). So it HAS to be about tool shape and position – not whether its at front or back.
                                          And again, I speak from experience because I had constant jam ups and dreaded parting off. Then I thought about it, realised that the back toolpost was part of the symptom not the cure. I ditched my back toolpost,  sorted out the angles,and nowadays I wouldn’t dream of such silly malarkey.
                                          Normally I use on the Myford a narrow 2mm blade,  but I have plenty of 3mm blades which have all been reground for special tasks like chamfering or handed parting, so they are cutting over a lot more than the nominal 3mm, and they work fine.(but they used to freak me out so easily would they jam) .
                                          I truly do not understand why anyone would want to feed forces into a machine in a way that it was, very plainly, never designed to accomodate. Thats just half witted. Its about as sensible as building a suspension bridge to take loads in tension and then asking it to resist an upward push in compression
                                          Its just not made to do it, and somehow that’s better?
                                          #50388
                                          chris stephens
                                            @chrisstephens63393
                                            Hi Guys,
                                            I just noticed that the topic is about parting on a C3 lathe, silly me, I should pay more attention shouldn’t I?
                                            Parting off on a C3 is not as easy as you would think, for those who are used to rigid tools (make your own jokes, if you must). The “as bought” sloppily made gibs on the C3  cause all sorts of dig-ins when parting. I am not knocking the Mini-lathe, you understand, but as bought, it only works, but with some serious attention can be made to work well. There is a WPS book on the Mini-lathe which I believe covers all the usual improvements, such as changing the bearings and  fixing the gibs. Using a rear tool post or an upside-down-in-the-front-in-reverse is not the answer to any parting problems. Understanding the problem is always the first step to fixing anything. The main problem with the Mini-lathe is that it is built to a cost not to a quality. Some may say that “it should be perfect from day one” and it could be but then the price would nearer a Wabeco. Regrettably these machines are, almost, sold as a kit of parts to be assembled by the new owner.
                                            I do not own a C3, or variant, but was I “teaching” kids at Ally-Pally on one and had great difficulty when parting. On close examination the top slide was moving quite markedly, and adjusting the gib screws was no help. In a quiet moment I took off the top slide and found that the dovetails were razor sharp and as everyone should know this is a bit of a no-no, when trying to match to a rounded valley. There was no way that the gibs could be adjusted correctly till things were worn enough for the main dovetails surfaces to meet. I might not have explained that well, but I know what I mean. Hopefully before our (SMEE) next teaching venture at shows, I shall have the time to bring the bits home  to my Engineerium to fix the problem. The fix should not be beyond the capabilities of anyone with Model Engineering skills, a bit of filing where needed and a bit of lapping with metal polish, together with a bit of gib strip pegging if found to be useful.
                                            So,  to the OP, I say this the Mini-lathe is, with some work, a quite capable lathe for the Model Engineer. It does need some attention though and parting off is one of those functions that needs attention to work successfully.. A lot of what other posters have said may be of help, like the Kit Q Cut, but nothing will help if your slides need adjusting or re-engineering. Don’t assume that your machine is perfect straight out of the box, ‘cos it ain’t necessarily so.
                                            christephens
                                            PS to any C3 owner might I recommend you read  the following;
                                             http://madmodder.net/index.php?topic=627.0  not only is the article a way to fix some of the Mini-lathe’s problems, it is also an education in the way to go about fixing  things engineering, written by a truly great teacher. IMHO
                                            #50390
                                            mgj
                                              @mgj
                                              Yes I was talking more generally and made the reasonable assumption that the lathe was properly adjusted and that the bits were capable of doing what the designer intended!
                                              Bearing changes I like – having just done one on the spindle bearings on my chinaman. Very smooth, very quiet, very consistent.
                                              Mind you, at £156 plus the vodka and tonic for a pair of German machine tool P5 grade taper rollers, I should darned well think so!
                                              (My original diagnosis about a retaining ring was wrong BTW – that was just a ring to hold the oil seal and had no effect on the bearing housing.)
                                              Edited By mgj on 03/04/2010 22:15:45
                                              #50397
                                              Gordon W
                                                @gordonw
                                                Thanks for all that mgj, more or less what I was thinking, normal tool mounting puts the load into the machine bed, which is where it should be. So have stopped making upside down holder and back to normal. Interestingly I never had much of a problem parting off, until I started reading the ME literature, but only did small bushes and the like. A tecnique I use for deeper cuts is to withdraw the tool, move over slightly to widen the cut, then go in again, this of course gives more side clearance. I feel lack of side clearance is often the problem.
                                                #50398
                                                mgj
                                                  @mgj
                                                  Gordon – you can do, but that problem is overcome completely by the indexable tipped tool.
                                                  The “blade” or carrier is say 2.5mm wide and the tip will be 3mm so there is a clearance from just behind the cutting edge of the tip. (Tthey are only full width for about 1mm max, all the way back.) So the set up only touches at the tip and is much less critical of grabbing. Also the tip will fold the swarf up, so coolant stays on all surfaces. So its much less prone to jamming. Add to that a shallow back rake, and there is no component  to draw the tool in. So they don’t ajm and you don’t need to move the tool sideways to gain clearance. Part off 2-3″bar at one slice with ease on a Myford.
                                                  You can perform a similar trick with ordinary ground blades, but all of them that I have seen are ground with a considerable back rake. Straight away there is that inward pulling component or vector. Add a smidgen of backlash, and the thing pulls forwards into the clear space allowed by the back lash in the feedscrew, and straight away you are in trouble. If the tool is above centre at the front or below centre at the back the cut thickens instantaneously and uncontrollably and a jam up ensues.
                                                  Its not clearance or wobble in the bearings – its excessive rake and inadequate clearance that causes the problem. Rectify that and you parting problems will disappear..
                                                  I tend to use 2.5 mm ISCAR GTN2 clone tips mostly. Nice convenient size.
                                                  #50399
                                                  Gordon W
                                                    @gordonw
                                                    I’ve been looking at the tipped tools ,which I think you are describing, not cheap but probabley worth saving for. How do you part 3″ bar ? Must be min. of 1 1/2″ overhang.
                                                    #50402
                                                    mgj
                                                      @mgj
                                                      Yes- I have a Sandvik blade which takes the same tips as the Kit Q cut.  – standard Sandvik tip. Its actually a blade for a 3mm tip, but you can shoehorn a 2.5mm tip in there.(cheaper)
                                                      Bring the tailstock with a rotating centre up, add blade overhang as you go along, lots of coolant as a jet direct into the slot!.
                                                      if you are looking for a good blade for the smaller machine, the Glanze clamp type from Chronos is a good one. The tip they provide is pretty naff , but Zenit do decent coated ones fairly reasonably. Thats an ISCAR clone, and it works very well.
                                                      Thats a better bet for the smaller machine than the Kit Q Cut (which is excellent) but it takes a 2.5 rather than a 2mm tip, and the narrower tip is better if one is a bit short of horsepower. Sandvik do do 2mm blades, but the assembly with clamp is a Father Xmas job. the Glanze is not.
                                                      Personally, I see no point in getting the holder type parting off tool. The tip is the same but it doesn’t have the reach of a blade, so it is limited. You can always retract a blade and run it with little overhang (good), but once the pinch type have reached their limit, thats as far as they go.
