Many thanks for these comments, as always they are helpful.
@David – will investigate these. 20 holes 7mm @ 2 inch deep for vacuum equpiment.
@Tim – yes, I have found it already. I do all what I can to ensure that reamer works as cutting rather than rubbing or cold forming device – but you know mistakes/errors do happen and drill 6.7 mm can on odd occassion cut a bit larger hole, particularly if hand sharpened.
@old mart – now I have lever operaed tailstock – it is God sent device for reaming. Handwheel ended up in box and wasn't seen from then onwards.
