Reaming Holes in Fixture Plate – What Type of Reamer
Home Forums Workshop Tools and Tooling Reaming Holes in Fixture Plate – What Type of Reamer
Viewing 25 posts - 1 through 25 (of 28 total)
  • #503019
    Colin Heseltine
      @colinheseltine48622
      I am currently making a fixture plate for use on my Bridgeport clone milling machine. Plate will be dual purpose as it will be also used to mount a Bison Indexer on the table.
      The fixture plate is 7/8" thick cast aluminium tooling plate and is 330mm x410mm in size. It will have rows of holes drilled into it, every alternate row will be drilled and then tapped M10. The alternate rows of holes are intended to take 10mm locating dowels made from 100mm silver steel bar. None of the holes will be through holes. I will be drilling to depth of 20mm and then either tapping or reaming as necessary.
      I have a MT1 long M10 reamer which is about 12inches long but I feel this too long.
      What type of reamer should I used as these are non through holes. I have seen some advertised which specifically say must only be used for through holes. Am I better with spiral blade reamer or straight blade reamer. Would prefer to stay with MT1 but could use chucking if this is all I can get.
      Colin
      Colin Heseltine
        #503021
        old mart
          @oldmart
          Use a solid carbide drill and lubricant and you won't need to use a reamer.
          #503023
          Colin Heseltine
            A have a few solid carbide drills but unfortunately 10mm is not one of them.
            Colin
            #503032
            jimmy b
              @jimmyb
              If i was to do this at work, I'd bore these to size.
              Standard machine/chucking reamers will have a small lead, you will just need to chamfer the end of you dowels.
              Jim
              #503034
              Emgee
                @emgee
                Colin
                For really accurate location dowels I would drill 9.5mm and then use a boring head to bring the holes to exact size,
                even with a short machine reamer there will be a small chamfer left in the bottom of the hole.
                Emgee
                #503037
                Mike Poole
                  @mikepoole82104
                  A chucking or machine reamer will have little lead or taper but to ream to the maximum depth a D bit would be useful, a hand reamer will be no use as you will not get past the tapered section. If the Dowels are a good fit then it may be useful to grind a small flat to stop the compressed air in the hole trying to pop the dowel back out, commercial dowels are available with the flat ready made and or an internal thread to help removal with a slide hammer or extraction block.
                  #503049
                  Vic
                    @vic
                    I saw someone online making a fixture plate and they finished the holes to size with a milling cutter. Just thinking out loud but any reason not to just drill a hole through the dowels to stop them popping out?
                    #503057
                    not done it yet
                      @notdoneityet
                      I think I would pilot right through and then counter-bore to depth – that avoids gas traps and crud collecting in the blind holes. Any tight dowels can be removed with access from behind the plate.
                      #503071
                      Colin Heseltine
                        Thanks for all the responses. I’m not sure I fancy boring out 51 10mm dia holes. If I drill the dowels (will only make 1/2 doz. ) to prevent air locks and put a thread in the top I will be able to pull them out and move them around.
                        If I use a 10mm slot drill will this give a dead size hole for the dowel. It would certainly be a lot easier than reaming.
                        Colin
                        #503072
                        Zan
                          @zan
                          Depends on your cutter. Try it in scrap.
                          if boring, get the head set to exact size after rough boring. Do this on a bit of scrap clamped On packing onto your tool plate, then coordinate bore all Holes at the same setting
                          #503078
                          IanT
                            @iant
                            A 'D' bit made from 10mm silver steel will certainly do the job in aluminium very well but as you can buy a 10mm slot drill for about £5 (in a standard metric size) it's not really worth making you own tooling for this.
                            IanT
                            #503079
                            jimmy b
                              @jimmyb
                              If you drill through, you'll still end up with "blind holes" to gather and trap swarf, once located on a flat surface.
                              Safest way to get the swarf out, is to poke an extended airline nozzle through a plastic/paper cup, put nozzle in hole and hold cup against the fixture plate, a quick blast should clear the thread.
                              Jim
                              #503087
                              Chris Evans 6
                                @chrisevans6
                                I would use a 10mm slot drill after drilling to 9.5 or 3/8"
                                #503093
                                Tony Pratt 1
                                  @tonypratt1
                                  Every method under the sun has already been suggested, all I can add is try your chosen one on a piece of scrap to see if you get a decent result.
                                  Tony
                                  #503094
                                  Mike Poole
                                    @mikepoole82104
                                    A few are recommending a slot drill which I must say I have not tried, I would have thought you could easily end up oversize with even a tiny spindle and chuck/collet runout, I also doubt that cutters are ground to reamer type tolerances. I think it would be worth a go to see what sort of fit you get and if it comes out as hoped for then happy days.
                                    #503098
                                    Tony Pratt 1
                                      @tonypratt1
                                      Posted by Mike Poole on 24/10/2020 08:38:44:
                                      Mike, totally agree slot drills are not designed for this sort of thing, reamers are but the OP may strike lucky.
                                      Tony
                                      #503103
                                      Martin Connelly
                                        @martinconnelly55370
                                        I would have thought that round steel pins into aluminium will wear the aluminium to the point where all your efforts to be accurate will be wasted. There will always be differences in where the holes are and where the pins are on a fixture to be mounted on it. Standard tooling practice is to buy and fit standard hardened steel location bushes and two matching pins, one of which is round and one lozenge shaped.51 bushes would be quite costly but you could fit bushes to one or two locations as datums and then add further ones if required in the future or if the plain reamed holes get worn to the point where they need repairing.
                                        If you are just planning to fit the dowels into the plate to act as stops then consider buying hardened dowels with threaded holes in them for extraction purposes. Hardened means they are less likely to pick up damage and jam in the holes, they should also be less oval/lobed than silver steel. Heat treatment of silver steel to harden it may cause slight distortion which will also cause problems
                                        Example of extractable dowel pins
                                        Martin C
                                        Did a quick check on the price of 32mm long Ø10 dowels with threaded extraction hole and air escape flat for blind holes, 10 off would be £5.20. 333mm of silver steel is similar or higher than this cost
                                        Edited By Martin Connelly on 24/10/2020 09:35:23
                                        #503104
                                        John Hinkley
                                          @johnhinkley26699
                                          I've got a couple of blunt and/or broken 10mm endmills knocking about the workshop waiting for a sharpening session. If I had this problem, I think I might grind of one or more flutes at an angle of, say 45°, depending on the number of flutes. That way you would end up with a fixed "boring bar" of 10mm diameter, assuming the endmill was accurately ground to 10mm in the first place! Wouldn't you? I haven't tried it, of course, it's just a thought that occurred to me while reading the thread. I think I'd give it a go, anyway, in some scrap first, of course.
                                          Edited By John Hinkley on 24/10/2020 09:09:39
                                          #503126
                                          Emgee
                                            @emgee
                                            Posted by Martin Connelly on 24/10/2020 09:07:54:
                                            Martin C
                                            This sounds to me like a very good answer to providing the easily removable pins, thanks for the link.
                                            Emgee
                                            #503136
                                            Anonymous
                                              I'd agree with Martin, use hardened dowel pins rather than make them. For the plain holes I'd probably use a chucking reamer in a collet. But experiment first on an offcut. Reamers are a bit hit 'n' miss when it comes to fine fits.
                                              Last night I used a 1" slot drill to "drill" a 1.4" deep hole in my cylinder casting ready for the governor valve. The resulting hole measures 1.001" according to my internal micrometer. Fine for my application, but not much good for a precision fit. So I wouldn't use a slot drill in this application.
                                              If I was going to be a perfectionist I'd make a D-bit, do a trial and cylindrically grind the D-bit as needed to sort out the last few tenths.
                                              Long ago I designed a fixture plate for the Tormach/Bridgeport of similar size to the OPs. I bought the jig plate …… but never got around to making the plate. I don't miss it in the least. I hadn't thought about it for ages until this thread appeared.
                                              I can't find the CAD model and drawing I created. But I'm pretty sure the tapped holes were through and the plain holes had a small through hole. I alternated tapped and plain holes along each row, offset by one space between rows.
                                              #503138
                                              Colin Heseltine
                                                Thanks everyone for the helpful advice.
                                                Going to have a play with the reamer, end mills and and boring head and see how things turn out.
                                                MartinC, I'm not sure how much use the plate will get as a fixture plate. I do not think I will get to the point where the holes become to slack to be accurate. Thank you for the link to Bonehams. Tapped, flatted dowels ordered.
                                                About to go in workshop and start by spotting all the locations and drilling through hole.
                                                Andrew,
                                                Great to see you back on the site and as always making good suggestions and points.  I intend having alternate rows of tapped and reamed holes. I am not sure how much use will be made of it as a fixture plate, but it is also has been machined with tenon slots and tapped holes to mount my large Bison indexer which is too wide to bolt to the mill table
                                                Colin
                                                Edited By Colin Heseltine on 24/10/2020 10:57:07
                                                #503141
                                                Martin Connelly
                                                  Just one little point regarding the hardened dowels. I would recommend using a black marker on the flats to make their position obvious to avoid placing the pins in a position where the workpiece is against a flat. The flats are not far off the radius but why run the risk of setting up against them?
                                                  Martin C
                                                  #503144
                                                  Colin Heseltine
                                                    Martin C,
                                                    Thats a very good idea.
                                                    Colin
                                                    #503150
                                                    Vic
                                                      @vic
                                                      These days you can get centre cutting end mills so I’d try one of those rather than a slot drill. As said I’d try it in some scrap first and perhaps stone the cutter as required if the hole ends up loose. I always keep silver steel in stock so often make dowels as required from it rather than buying them in ready made. I don’t bother to harden them as it’s not required for many jobs. Good luck with the project!
